Bathroom Fan Installation - Weight Check - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-26-2017, 09:28 PM   #1
Rewards Points: 2
Bathroom Fan installation - weight check
Hello all,
I just replaced a bathroom fan/light with a new pansonic whisperfit fan / light. It is 13 pounds and appears to be working fine. Due to my house being older, the bathroom beams are closer and I couldn't use the supplied mounting brackets.
I called up my father and he suggested using 4 long industrial screws vertically directly into the beams would work. Does this make sense for a 13 pound unit which seems balanced and is working? Any risk of it coming through the ceiling.
BasementSkill is offline   Reply With Quote
Old 03-27-2017, 06:29 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,294
Re: Bathroom Fan installation - weight check
Screwing into the wood framing should be fine to support the weigh of the fan.
The newer fans are so balanced that the static 13lbs is going to be felt as less than a builders grade fan at less weight that is not as well built.
If you haven't done it yet, it sounds like you can box out that are a bit and just use some framing lumber to create the proper sized pocket that you need to then attach the fan box to directly.
Old 04-02-2017, 07:35 PM   #3
Professional
Rewards Points: 188
I like your dads advice but if you can fit some blocking between the fan unit and ceiling joists just for a spacer it might help make for a tidy install. I like those Panasonics.
Str8AheadInc is offline   Reply With Quote
Quiet Check Valve Installation shane1234 Plumbing 3 08-04-2015 05:02 PM
Installation of bathroom exhaust fan drew242424 General DIY Discussions 7 01-13-2014 03:55 PM
bathroom circuit size..... CharlieR Electrical 14 03-25-2012 02:52 PM
Bathroom fan installation noviceshock General DIY Discussions 11 01-21-2012 09:25 PM
Should I Caulk perimeter gap in floating vinyl plank bathroom installation chuck_250 Flooring 2 11-22-2010 07:35 PM
