Bathroom Fan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-20-2016, 10:39 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
Bathroom fan
Is there any harm in installing a higher CFM rating fan in a smaller room?
Barry J is offline   Reply With Quote
Old 03-20-2016, 10:47 AM   #2
Rewards Points: 5,778
Re: Bathroom fan
Energy, noise, and heat loss, but otherwise no problem .
There is also the issue of make-up air as you will need more air coming in with a larger fan.
If you are addressing moisture on the walls, consider a low flow shower head that has a volume adjustment at the head. I find they work well at reducing the total amount of hot water used and thus the amount of steam.
of course I'm more successful at controlling the steam now that mu daughters are out on their own.
The other item you might consider is a delayed-off switch. these are used to keep the fan running for a preset time after you exit.
Bud
Bud9051 is online now   Reply With Quote
Old 04-05-2016, 07:30 PM   #3
Rewards Points: 40
Re: 2ea. Bathroom venting
Nah not going to beat the ventilation dog again, but here is a twist ?
Remodeled both baths in my condo. Both vented to the outside
separately with metal duct above in attic. I disassembled ducts,
installed insulation sleeves to all tubes. (condensation issue)
Now picture a big "Y",. . top is from baths which now meet at a wye, combining into one duct, travel 15ft. as one then go to the
outside thru exhaust flapper.
installed additional baffles at inlets to wye, to reduce possible siphon,
and vacuum. (overkill that's me)
Anyway, I have now connected two baths to a trunk line.
LEGAL? ?? Code says ??
I've seen motels feed to a common trunk line of the same size.
I snitched the one, now extra duct to handle a kit hood vent!
I'm in Michigan . . . . . . and its snowing !
whats the verdict?
THANKS
Scout10 is offline   Reply With Quote
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 07:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
