Bathroom Exhaust Fan Problem: - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-31-2014, 09:21 PM   #1
Rewards Points: 67
Bathroom exhaust fan problem:
A few months ago I had The World's Worst Contractor add a bedroom/bathroom addition on our one-story ranch house. I don't want him back here, EVER, so I'm trying to fix problems myself.
(Let's just skip the discussion about suing him, etc., just not worth it.)
There's a rather expensive round Broan exhaust fan/heater/light in the bathroom. When the heater is not in use, cold air pours down through the vents into the bathroom.
What can I do to fix it? TIA.
oldberkeley is offline   Reply With Quote
Old 10-31-2014, 09:40 PM   #2
HDS
Rewards Points: 318
Where does it exhaust to?
HDS is offline   Reply With Quote
Old 10-31-2014, 10:23 PM   #3
Rewards Points: 462
It sounds like the flap is missing that is supposed to prevent air from blowing back through when the fan is off.
Jim F is offline   Reply With Quote
Old 11-01-2014, 08:43 AM   #4
Rewards Points: 67
Follow-up question:
HDS & Jim- Thanks for your prompt replies.
HDS, I'm not sure about that. Knowing this contractor, it probably vents to NOWHERE!
If this is true, and Jim's idea is correct about the flap, what can I do????
TIA
-Gary
Old 11-01-2014, 10:35 AM   #5
Civil Engineer
Rewards Points: 5,246
You need to trace the vent duct from the source (the fan) to the point where it exits the house. If it does not exit the house, i.e. it exhausts into the attic, you need to replace the exhaust piping and carry the outlet to the outside, which may require cutting a hole in the siding or the soffit. Impossible to say without details of your installation. But it all starts with you tracing the exhaust duct. There are usually flaps that prevent cold air from backing into your fan housing, maybe the system was installed without one, in which case you need to add it, and possibly reroute the duct as well.
Old 11-02-2014, 11:49 AM   #6
Rewards Points: 462
You will see the flap once you remove the light assembly and bent cover. It should be in plain sight between the fan and exhaust where it connects to the duct if there is one. In any case, taking the vent apart might answer some questions as to why it is not keeping cold air out.
Old 11-02-2014, 04:32 PM   #7
Bill Kearney
Rewards Points: 1,174
Fantech and others sell in-line dampers than can be added, further up along the ducting. Might be useful if yours can't be made to work properly.
I have to add them to ours to cut down on wind gusts causing the dampers on the grilles to flap.
-- Bill
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Jim F (11-03-2014)
Bathroom Exhaust questions flashinm HVAC 8 03-10-2013 05:37 PM
Bathroom Ducting with Relation to Exhaust Fan illusion8055 HVAC 3 09-10-2012 03:30 PM
Bathroom exhaust through roof Dugams Roofing/Siding 28 09-01-2012 02:51 PM
Can bathroom exhaust and dryer share same outside duct? benze HVAC 17 09-08-2010 02:24 PM
Bathroom exhaust - ceiling damage KMARTEL HVAC 1 10-04-2007 09:21 AM
