Bathroom Base Moulding - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-03-2014, 09:11 PM   #1
Rewards Points: 12
Bathroom base moulding
We're putting white, wood, colonial style base moulding throughout the house, but we don't want to put wood base in the bathroom. I can't find a vinyl base that matches the style of the wood base. I can find vinyl in the same height, but not exactly matching style. Does it have to match the rest of the base in the house? If so I may have to consider using tile as base, but I really wanted white since the bathroom is dark gray walls and shower tiles and light gray floor. Also the floor tile does not offer a bull nose tile so even that would not match the floor exactly.
Juniper94 is offline   Reply With Quote
Old 12-03-2014, 09:19 PM   #2
Jello Wrangler
Rewards Points: 539
If you are stuck on wood and not tile why not just go with the same? Prime and one coat the back. Prime and titebond your corners and walk.
ChiTownPro is offline   Reply With Quote
Old 12-04-2014, 08:47 AM   #3
Rewards Points: 17,896
Why not wood base? It's done all the time.
As mentioned just seal it on all sides.
Plastic is a pain to work with, it likes to melt instead of cutting, chips, cracks if it's nailed to close to an outside edge.
Juniper94 (12-04-2014)
Build out base moulding Huskyfan68 Carpentry 5 12-04-2012 04:55 PM
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-24-2012 11:23 PM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
