Bath Tub - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 05:34 PM   #1
Bath tub
Which is the correct way to framed tile onto the bath tub, should the tile framing be elevated/raised above the tub or tub elevated/raised over the tile framing?
K. Johnson is offline   Reply With Quote
Old 06-06-2012, 06:27 PM   #2
Rewards Points: 17,890
There is no such thing as "tile framing".
The studs behind the tub get framed, and tile gets laid.
Did you install 1/2 tile board and water proof it yet?
Most often it's best to shim out the studs so the tile board can be installed so it sits just over the tub lip, the tile is set so it's about 1/4 off of the top of the tub, this area gets filled in with caulking, not thin set.
Inline Bath Vent Switch Wiring Dano81 Electrical 3 05-09-2012 10:52 PM
Relacing a shower with a half bath seth Building & Construction 9 11-22-2011 10:58 AM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
