Bath Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-08-2015, 09:58 AM   #1
Rewards Points: 6
Lightbulb
Bath Remodel
I am renovating a bathroom in a house flip and have a some questions on the flooring. I am wanting to install vinyl tile that can be grouted. I currently have particle board subfloors. I have seen where I cannot but the peel and stick tiles over this type of subfloor, so I am going to put down and underlayment. Can I use 1/4" wall panels that I took down from the kitchen? These have one side that is smooth and one side has grooves that look like panels. I was thinking of putting the panel side face down so that Im left with a smooth surface for the tiles. Would this be a good idea? Also, is it better to grout the tiles or caulk them? Thanks!
leecj45 is offline   Reply With Quote
Old 01-08-2015, 10:12 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,504
What are the panels made of?
Why do you want to rout vinyl tiles? I never heard of that.
Old 01-08-2015, 10:42 AM   #3
Rewards Points: 6
The panels are plywood. Just like 1/4" luan except they have the cosmetic design on one side. The vinyl tiles that I am installing are new the new kind that you grout after installation. Just makes them appear to be real tile.
Old 01-08-2015, 11:03 AM   #4
Rewards Points: 144
Luan is not a good choice under vinyl.Especially in a bath where there is moisture.The laminations will separate.
Since you did not post your location I don't know if you have a Menards in your are but they sell a peal and stick tile that is heavier and has a rounded edge that is made for grout.I have installed quite a bit of it and was pretty impressed of the look and durability for the cost.
mako1 is offline   Reply With Quote
Old 01-08-2015, 11:23 AM   #5
Super Moderator
joed's Avatar
The wrong kind of plywood under vinyl will bleed colour though the vinyl. But heh it's a flip, do whatever is cheap and easy. The next guy will deal with it.
Old 01-08-2015, 11:37 AM   #6
Rewards Points: 144
I just love this kind of thinking
Old 01-08-2015, 12:38 PM   #7
Rewards Points: 6
mako1 what sort of underlayment would you recommend me using? I am in South Carolina. Even though I'm flipping the house I still want it to be done right. Would priming the luan with kilz be better?
Old 01-08-2015, 01:09 PM   #8
Rewards Points: 144
No.Priming with Kilz would not do much good.You can us a 1./4" underlay to not raise the floor.Look for the manufacturers suggestions on the floor you buy..There are a lot of optioms.
Old 01-08-2015, 01:46 PM   #9
Super Moderator
joed's Avatar
You need a plywood specifically listed as underlayment. You should refer to your flooring material data sheet for anything specific they require.
Underlayment is made with no gaps on the inner layers and usually sanded smooth among other things.
The Following User Says Thank You to joed For This Useful Post:
oh'mike (01-08-2015)
Old 01-08-2015, 05:18 PM   #10
Rewards Points: 462
I used this http://www.patriottimber.com/hardwoo...-underlayment/ bought it at Lowes. You'll pay a little more but bathrooms are usually not too many square feet. It's good to get an underlayment with the fastener markings. They help an amateur like myself do the job right.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
2 1/2 storey remodel 4 bed, 1 bath to 7 bed, 5 bath qc_riderfan87 Plumbing 15 07-25-2012 09:07 AM
Master bedroom and bath remodel toocheaptohire Kitchen & Bath Remodeling 1 03-06-2011 08:22 PM
Master Bath Remodel - Need Advice meth Building & Construction 8 12-07-2010 05:31 PM
Ricks bath remodel - please help RICK430 General DIY Discussions 1 05-19-2009 09:36 PM
Bath remodel wiring Nhrafan Electrical 14 03-23-2007 05:53 PM
