Bath To Bath/shower Conversion - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-19-2014, 10:58 PM   #1
Bath to bath/shower conversion
Recently added a shower to a bath only tub. Accessed plumbing from opposite side of wall inside closet. Being that the bath did not have a shower before, the tile is only run about half way up the wall. What should I do to protect the remaining walls from water damage.
Bath to bath/shower conversion-image.jpg
DoitMyselfAgain is offline   Reply With Quote
Old 07-19-2014, 11:23 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Add tile maybe ?
The problem now is the walls aren't suitable for a shower. Putting tile on what is there now will only provide a couple of years service before erosion and decay sets in. Are the walls drywall or plaster?
The correct thing to do is to remove what is there down to the studs and start over using proper shower enclosure methods if you want tile.
One other option is to add some plastic shower surround panels.
XXX
Old 07-19-2014, 11:34 PM   #3
Yes the walls are sheet rock. Trying to find something relatively low cost, had thought about shower panels, are there panels you can cut to fit a space such as the one above the tile?
Old 07-19-2014, 11:58 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes you can buy "cut & fit" panels.
XXX
Old 07-20-2014, 12:04 AM   #5
Do you apply them directly to sheet rock and do you think it would really prevent water damage underneath?
Old 07-20-2014, 01:37 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can apply them directly to almost anything but be sure to use the proper adhesive. If installed properly they will last for a while. They also have to be caulked properly. Drywall isn't usually recommended for a shower substrate, but, OH WELL, it appears you are heading in that direction no matter what!
XXX
access panel preventing basement bath conversion? rook81styles Remodeling 23 10-16-2014 04:42 PM
Half Bath Conversion kingbuggy Plumbing 5 05-03-2012 09:13 AM
converting bath to bath/shower vapor barrier question timgwen Tiling, ceramics, marble 4 06-22-2011 02:35 PM
Basement 1/2 bath--full bath conversion Demochick Project Showcase 2 06-30-2008 09:03 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
