Bath Base Molding Replaced - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2018, 06:06 PM   #1
Licensed Engineer
Rewards Points: 467
I posted about a month ago asking for advice on the best method to remove the old circa 1978 hideous gold ceramic base molding in our main bath. The old base molding tiles came off with a broad putty knife struck by a hammer along the upper edge of the tile as step #3. Step #1 was using the same putty knife to fracture the grout joints between the tiles, and Step #2 was to fracture the joint between the base molding tiles and the 1x1 ceramic tile floor.
Tiles were removed a week ago Saturday. New wooden base boards were installed working 2 hours per evening four nights after work, and the final push was a few hours Saturday morning to finish the toe molding, puttyinail set holes, and give the boards their single "post install" coat of paint. Each board received two coats of paint prior to being installed.
I am pretty proud of my joint work on this job! My wife abandoned trying to putty the joints to seal them because they were so tight the putty could not enter the joint! Outside joints are miters obviously, inner joints are all coped by hand.
Not bad for an old geezer of an engineer with bifocals and a cataract who does woodworking just for a very sporadic hobby.
The new wall color matches the gray tiles in the floor pattern.
The thicker return piece in photo#1 is because the old ceramic base tile was installed partially against cement board that extended slightly from the original tub surround wall tile (explains the visible and mysteriously thick grout layer that existed behind the tile since original construction). The tub received a plastic liner about 15 years ago that was sloppily coped around the base tile and hidden behind silicone caulk.
I had to scratch my head a bit to come up with a method to compensate for the now missing 1/2-inch cement board, and the ragged tub surround coping relief, without using a big ugly goober of caulk. I turned a scrap piece of the new 1/2-inch thick baseboard backwards and upside down, cut it long enough so that the hidden end bears against the original tub wall, then glued and nailed the blocking piece, visible return piece , and end piece together before fitting them to the wall. Once against the wall the assembly was nailed to the wall studs.
MI-Roger is offline   Reply With Quote
Old 01-30-2018, 06:19 PM   #2
retired framer
Rewards Points: 18,610
Re: Bath Base Molding Replaced
Bragging right. Looks great.
Old 01-30-2018, 10:17 PM   #3
jlhaslip's Avatar
Rewards Points: 708
Looks great. you should be proud of the project.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-31-2018, 05:51 AM   #4
Peace be with you
DR P's Avatar
Rewards Points: 1,860
As my high school principal
announced at graduation:
"You Done Good"
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 01-31-2018, 06:35 AM   #5
ZTMAN's Avatar
Rewards Points: 278
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 01-31-2018, 06:53 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 606
Looks good. My criticism is using 1/4 round instead of shoe molding.
Sent from my XT1095 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 01-31-2018, 08:07 AM   #7
Rewards Points: 6,889
Nice attention to detail.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 01-31-2018, 08:54 AM   #8
Licensed Engineer
Rewards Points: 467
Nope. Optical illusion caused by camera angle, I used the correct 1/2 x 3/4 Shoe Molding (my Dad always called this Toe Molding but Shoe is the correct current term). I preferred the look of no shoe/toe molding at all, but the floor finish elevation varied so much along the single longest side that caulking the joint below the base molding would have looked horrible.
Base molding questions msaeger Carpentry 14 02-13-2014 03:30 PM
Base molding in this closet? Tricky. Dave88LX Carpentry 25 02-22-2013 09:21 AM
base molding painting w/ carpet fabian Painting 2 04-02-2009 07:57 PM
Base molding helpless handyman Carpentry 16 04-01-2008 05:06 PM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 08:29 AM
