Bath Alcove - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-11-2015, 03:15 PM   #1
Rewards Points: 16
Bath alcove
I'm building a bath alcove for a new tub along a wall that is adjoing another house. This wall has been somewhat sound proofed by the builder using 1/2 or more plywood over the studs then 5/8 drywall over the plywood. This alcove will be tiled above tub up to about 8'. I am planning on using a vapor barrier attached to studs then 1/2 hardi over that tiled with subway tiles up to the 8' mark.
My question is wether there will be an issue with attaching the 1/2 hardi backer board directly to the plywood. I'm sure I'll loose some sound deadening but thats not too much of an issue. I'm not planning on using thinset on the plywood just attaching vapor barrier then backer board.
does anyone see an issue with this?
jiarchibald is offline   Reply With Quote
Old 08-11-2015, 03:24 PM   #2
Retired Moderator
Rewards Points: 7,174
Do you have a picture?
Tub is typically attached directly to the studs---you are saying that the back wall is drywalled BEFORE the tub was installed?
I would skip the plastic vapor barrier and water proof the face of the backer board, using Red Guard or Hydroban---
jiarchibald (08-11-2015)
Old 08-11-2015, 03:35 PM   #3
Rewards Points: 16
Thanks for the reply, Don't have pics.
The room was drywalled previously but unfinished. I am removing the drywall on all three sides and reframing the alcove on two sides to so that the studs will be at 60'' apart for the tub that I ordered. the back side of the tub will have the dry wall removed up to 8' since that will be the height of the "alcove" that I am framing and I'm planng on using the 1/2 hardi plank on all three sides of the alcove. The hardi plank will be fitted over the tub flange which means I'll have to use trim boards so minimize bowing of the hardi plank. hopefully that helps
Old 08-11-2015, 03:42 PM   #4
Retired Moderator
Hardi BOARD--I hope--not PLANK---
I prefer Durrock--but the choice is up to you--however, they are both installed the same--stopped above the flange---not over it
The resulting gap is filled with thinset---
Old 08-11-2015, 03:58 PM   #5
Rewards Points: 16
Yeah the Board not plank or Durrock I haven't decided yet. but you see no problem with attaching it directly to the plywood. I wouldn't think there would be an issue.
Also you suggested using a paint on water proofing.
So would I attach hardi/durrock to studs and drywall as specified by manufacturer. Not over flange!! tape, thinset then paint on use water proofing. Then thinset for tiling. Tile the walls with my subway tiles then use a waterproof grout. Bam Bam done!
Old 08-12-2015, 05:38 AM   #6
Retired Moderator
That is it, in a nut shell---
Tags
hardi backer , plywood wall
Header needed in alcove install? NVhunter83 Building & Construction 39 12-31-2013 10:25 PM
Inline Bath Vent Switch Wiring Dano81 Electrical 3 05-09-2012 10:52 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
