Basement Shower - Concrete Walls - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-01-2017, 03:51 PM   #1
Rewards Points: 138
I have a basement shower that has concrete floor, 2 walls that are concrete and one that is framed. The previous tiled shower was done with no leak protection whatsoever...only thinset and tile over the walls and floor. I removed all tiles. I tried to grind flat but no way. The floor and walls are uneven from previous thinset.
I am considering RedGard-ing Concrete Walls, Framed Wall (after putting new concrete board on it) and the Concrete Floor. But I need to prep first. I need to know what materials to get in order to prep the Concrete Walls and the Concrete Floor so that my substrate in flat/plumb/etc and will then accept redGard and then tile.
(note: i have heard some folks suggest framing over concrete walls but there is no room for that. this has to be some sort of morter solution to true up the walls.)
bobmane is offline   Reply With Quote
Old 11-01-2017, 04:28 PM   #2
Rewards Points: 138
Re: Basement Shower - Concrete Walls
here are a couple pics
Basement Shower - Concrete Walls-20170622_121532.jpg   Basement Shower - Concrete Walls-20170625_081008.jpg
Old 11-05-2017, 03:14 PM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,126
gotta ask: why?
... I need to know what materials to get in order to prep the Concrete Walls and the Concrete Floor so that my substrate is...
Not a material. LABOR. Lots of it. And some masonry grinding tools.
And vacuums. And dust masks too.
I recommend it highly when that time comes.
Old 11-05-2017, 05:12 PM   #4
Rewards Points: 138
Tile removal was a huge mistake that is correct.
I am not going to grind the walls flat need other solution.
Removing Shower Pan From Concrete Basement Floor heyjoe91 Plumbing 8 01-07-2015 08:10 AM
How to finish concrete walls in cold storage room (basement) TomU Concrete, Stone & Masonry 6 11-11-2012 06:40 PM
vapor barrier plus inside the basement when walls are sealed with a penetrable sealer concrete walls myhouse2010 Building & Construction 1 10-17-2010 11:35 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 12:44 PM
