Backsplash Tiles - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Guap0_
  • 1 Post By Ctran87
Old 12-20-2017, 04:11 PM   #1
Backsplash tiles
Hello everyone,
First time poster here. I recently redid my kitchen backsplash with white subway tiles. I posted a picture of the problem I ran into and was wondering if anyone else have ever experienced this. The tiles behind the stove turned out a bit crooked due to the drawers to the left of the stove is an inch higher then the countertop of the right. I didn't know this at the time I was tiling. This is actually my first time doing any type of tiling.
I tiled from left to right which caused the crookedness along with my ceiling not being leveled.
What would the more veteran/pro tilers have done?
Actually nevermind on posting a picture, as I see I am to new to attach a picture.
Ctran87 is offline   Reply With Quote
Old 12-20-2017, 04:21 PM   #2
Guapo
Rewards Points: 11,950
Re: Backsplash tiles
Try posting the pic again. If that doesn't work, use imgur.
Guap0_ is offline   Reply With Quote
Old 12-20-2017, 04:44 PM   #3
Couldn't edit one in. So here it is
Old 12-20-2017, 04:49 PM   #4
jlhaslip's Avatar
Rewards Points: 708
If it was me doing the work, I would have used a laser or level to set a line flat across the wall behind the stove and cut the tiles at the first row on the taller of the cabinets.
Cutting pieces to fill in under the right hand side would look goofy.
Are the bottoms of the upper cabinets level with each other?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 12-20-2017, 05:05 PM   #5
Guapo
It doesn't look that bad to me. Since they are subway tiles, put a sign under the hood that says West 4th St Manhattan, my favorite stop.
https://i.ebayimg.com/thumbs/images/...Na9/s-l200.jpg
firehawkmph likes this.
Old 12-20-2017, 05:08 PM   #6
Yeah, I was actually thinking about ripping the tiles behind the stove out all the way toward the fridge and redoing it. What I did originally was put a ledger(?)(not sure what it's called) across from one top to the other as if the countertop we're just one big piece.
Old 12-20-2017, 05:36 PM   #7
Haha, that's a funny/cool idea.
Guap0_ likes this.
Old 12-21-2017, 10:29 AM   #8
Breakin' Stuff
Rewards Points: 1,360
I probably would used a laser level like jlhaslip mentioned, then cut the bottom tile on the high side so that it lined up.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 01-18-2018, 01:15 PM   #9
Rewards Points: 20
It's been a month since the last post so I don't know if you've fixed this or abandoned the idea or ??? I think all you can do is disguise the problem, so here goes if you are considering re-tiling...
1. Rip them all out and go with a taller tile row in maybe gray as the bottom course, cutting each one's bottom to fit to a laser line parallel to the cabinet bottoms. The taller the bottom course, the less noticeable the adjustments will be.
2. Rip out only the tile row that meets the cabinet bottoms and the row above it. Replace the two rows with maybe a single gray square tile band row. This would be easier but more noticeable than the first.
FitzJohn_1960 is offline   Reply With Quote
Marble Backsplash for Kitchen DrDIYer Concrete, Stone & Masonry 2 05-09-2013 07:13 AM
Best way to cut mosaic tiles for backsplash pdp76 Concrete, Stone & Masonry 7 04-16-2013 11:29 AM
backsplash tiles for the kitchen Deepika Tiling, ceramics, marble 2 04-18-2011 09:18 PM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
Tin 18x18 tile's for backsplash.... dcd22 Remodeling 1 10-09-2007 04:12 PM
