Backsplash On Painted Sheet Rock - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-09-2015, 10:56 AM   #1
Rewards Points: 12
Backsplash on Painted Sheet Rock
Can I put a kitchen backsplash on a latex painted wall (sheet rock)?
If so does the wall need to be scuff sanded first or a primer applied?
I will be using a natural stone tile and natural stone mortar/thinset.
Also any suggestions on grouting over metal tile inserts, how to keep them clean when grouting? I'm thinking of using painters tape to cover them.
natspawpaw is offline   Reply With Quote
Old 09-09-2015, 11:03 AM   #2
Rewards Points: 5,348
Thin set is pretty tenacious in it's grabbing ability but it won't hurt to scuff up a semi gloss or gloss paint.
If the metal inserts are smooth and you're using an unsanded grout, you shouldn't need to cover the metal. Sanded grout might scratch the surface and get stuck into any design in the metal.
Clean off the sanded grout as soon as directed. Too long on the tile is a bear to remove. Unsanded grout is much more forgiving in that way.
Ron
B. Franklin 1759
Old 09-10-2015, 07:29 PM   #3
Jello Wrangler
Rewards Points: 539
Used a modified thinset designed for natural stone. Roughing up the paint is the min I would do. I would sand the walls then prime with a good PVA primer. Let it cure and then tile. I have had great success with this method.
ChiTownPro is offline   Reply With Quote
Tags
backsplash , metal tile inserts , sheet rock
moister comming through sheet rock francisno7 General DIY Discussions 3 03-03-2014 03:32 PM
Removing wall latex paint from sheet rock ceiling dehlila123 Painting 3 10-18-2011 01:04 AM
Average cost for taping sheet rock navidave95 Remodeling 20 07-21-2011 03:58 PM
panel glue off sheet rock richard1980 Building & Construction 2 09-17-2010 09:02 PM
What size sheet rock for garage ceiling? Billy Boy General DIY Discussions 12 01-24-2008 12:36 PM
