Backsplash Nightmares (cabinet Related) - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 3 Post By Toml
  • 1 Post By Toml
Old 12-04-2017, 10:59 AM   #1
Backsplash nightmares (cabinet related)
I have a real ugly backsplash that I'd like to remove...
The backsplash has the look of stainless steel, but it's 3/4" plywood with a foil-like laminate on it. It's probably at least 15 years old. It's really nasty.
I was about remove this backsplash during a small remodel, but then it occurred to me there must be a reason for using this thick plywood instead of something thinner. I looked in the wall cabinets above and I can't find many screw heads for fasteners to keep the cabinets on the wall (I found 4 across the top of a 36 inch cabinet), so it's possible someone used this plywood as a support for the cabinets.
I know there might be fasteners I can't see, on the back of the cabinet, but how could I tell? I'd always assumed the cabinets were secured to the wall properly. I really don't want to get into removing wall cabinets.
My questions are:
1) is there a way to tell if the cabinets are secured to the wall correctly, without removing the cabinets? The wall is drywall, then a 1/2" spacer, then concrete block.
2) assuming I can't verify 1 - what are my options for removing this ugly backsplash but keeping support for the cabinets? I was hoping to have a tile backsplash and I want to avoid losing more counter space to a thicker backsplash; could I replace the plywood with 1/2" concrete backer and tile over it?
Toml is offline   Reply With Quote
Old 12-04-2017, 11:14 AM   #2
retired painter
Rewards Points: 1,328
Re: Backsplash nightmares (cabinet related)
Your upper cabinets would receive little if any support from the plywood on the wall below it. Sometimes cabinet screws can be hard to spot. You'll want a light and look under each shelf. The screws should be about 16" apart and in a straight line from top to bottom.
The odds are you have 3/4" thick furring strips between the drywall and the block.
mark sr is offline   Reply With Quote
Old 12-04-2017, 02:06 PM   #3
I took another look. The only screws inside that cabinet are the four along the top, about 7-8 inches apart. There's also another 3 screws from the neighboring floor-to-ceiling cabinet into this one.
I have another larger cabinet, about 5 feet in length, with only 4 screws that I can see - two into the same wall as the first cabinet and 2 into a wall with steel studs. This larger cabinet has the same backsplash on one side and a 1/2 inch board between it and the counter on the other.
Removing these boards will be fun too - they appear to be screwed and glued to the drywall.
Old 12-05-2017, 08:24 AM   #4
Well it didn't fall down
Taking it off wasn't so bad, I used a circular saw to cut up some pieces and a claw hammer to pry it off the wall.
SPS-1, Skoorb and Mike Milam like this.
Old 12-07-2017, 09:37 AM   #5
Rewards Points: 104
Nice. So that went better than when I removed my tile back splash recently (destroyed all the drywall, currently in the process of repairing it).
My cabinets, even the fairly large one that holds all the dishes, are held by few screws. In the case of that one the cabinet's weight plus all dishes are maintained only by four screws that sink in no more than about 1 1/4 into the stud behind.
I wanted to see pics of your nasty plywood backsplash
Skoorb is offline   Reply With Quote
Old 12-07-2017, 02:20 PM   #6
Lol, attaching pic... that's the ply, with nasty foil on it, after I went at it with a chisel trying to remove only the foil.
Skoorb likes this.
Old 12-07-2017, 02:49 PM   #7
retired framer
Rewards Points: 18,480
24 gauge stainless back splash. Is what you had.
https://www.commercemetals.com/stain...en-backsplash/
Finally mounted upper kitchen cabinet to sloped wall! stripedbass Carpentry 7 01-30-2015 01:23 PM
Cabinet, Fridge, & Pantry fitment mystic_cobra Carpentry 8 01-17-2012 12:36 AM
Wall cabinet mounted next to pantry cabinet ryan.kelly Carpentry 2 10-13-2011 07:50 AM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
