Aligning P-trap And Sink Drain. Best Setup. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Nealtw
  • 1 Post By Yodaman
  • 2 Post By greentrees
Old 03-04-2019, 05:24 PM   #1
Rewards Points: 735
Aligning p-trap and sink drain. Best setup.
I have a 1 1/2 inch pipe from the bathroom wall. The existing PVC pipe has a 1 1/2 inch p-trap. There is a reducer to 1 1/4 inch after the p-trap. What is the best setup to attach the p-trap to the 1 1/4 inch drain? The photos shows the gap.
note: I still haven't figured out how to get the photos loaded in the right orientation. I probably have to hold my camera sideways so it loads correctly. It seems the photos loaded in landscape.
Aligning p-trap and sink drain.  Best setup.-20190304_084930.jpg   Aligning p-trap and sink drain.  Best setup.-20190304_084951.jpg   Aligning p-trap and sink drain.  Best setup.-20190304_085053.jpg
greentrees is offline   Reply With Quote
Old 03-04-2019, 05:57 PM   #2
retired framer
Rewards Points: 17,952
Re: Aligning p-trap and sink drain. Best setup.
Do not use flat bottom gables with scissor trusses.
Old 03-04-2019, 06:06 PM   #3
Rewards Points: 735
Thanks for the link. The piping has a vertical and horizontal gap. The link provides a solution for one, but not the other.
Old 03-04-2019, 06:42 PM   #4
retired framer
I would start over from the wall with new with an angle that will get you going in the right direction.
Yodaman likes this.
Old 03-05-2019, 10:30 AM   #5
Rewards Points: 2,119
If I'm right, the video Neal linked shows you how to bridge the vertical gap. Surely you can figure out how to extend the pipe from the wall a bit?
huesmann is offline   Reply With Quote
Old 03-05-2019, 10:48 AM   #6
Property Mgt/Maint
Rewards Points: 6,312
Proper way to do this is cut off the outlet near the wall, and build it back out using a elbow (maybe 45 degree). The trap should start at the bottom of the tail pc.
You can buy goofy accordion tail pcs, but you will likely have problems with it.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 03-06-2019, 12:03 AM   #7
Rewards Points: 735
I found an extension but not sure if that would work with the black PVC pipe. Can I screw one end into the pipe since it has threads. I would probably have to use some Teflon tape since the water flows into the threads.
I found a 45 degree adapter but not sure if this would work better then the extension.
Aligning p-trap and sink drain.  Best setup.-046224007685.jpg   Aligning p-trap and sink drain.  Best setup.-extension.jpg
Old 03-06-2019, 07:44 AM   #8
Property Mgt/Maint
Based on your last question, you may need some on site assistance.
The tail pipe extension is correct. The 45 is not. I would remove all the black pvc and discard. Looks like the white to black transition is threaded. That is good. You can unscrew the entire trap assy buy turning it CCW.
I will post again with the adapter and pcs required.
Nealtw likes this.
Old 03-06-2019, 08:00 AM   #9
Property Mgt/Maint
First a new thread to slip adapter,
https://www.homedepot.com/p/Charlott...00HD/203811414
Then use a street elbow,
https://www.homedepot.com/p/NIBCO-1-...D112/100677990
Next you will need a short length of 1 1/2 PVC pipe, not sure on length maybe 3-6".
Now the Trap adapter
https://www.homedepot.com/p/NIBCO-1-...D112/100345781
Trap assy https://www.homedepot.com/p/Everbilt...704B/205153793
Then you will likely need the tail pipe extension too. Not sure on length, buy long, and cut to fit at assy.
The slip fit fittings you will need PVC primer and glue, the threaded fitting at the wall will use PVC tape to seal, and the adjustable trap assy pcs will use a plastic seal. You can brush the seal with a little Teflon paste or use nothing at all.
Dry fit everything before you open a can of glue.
Old 03-07-2019, 08:59 PM   #10
Rewards Points: 735
Wow. Nice breakout of the parts. I have a few of these items. I'll have to pick up the rest when I go to the big box store.
Yodaman and Nealtw like this.
Tight fit sink drain and trap project homeimproverjoe Plumbing 5 04-20-2018 09:18 AM
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 09:13 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
