Advice Regarding Concrete Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-05-2013, 11:17 AM   #1
Rewards Points: 294
Advice regarding concrete floor
I have my 2nd floor bathroom down to the studs in my 87 year old home. Now facing a decision on whether or not to take a jack hammer to the two inches of concrete in the floor, or simply remove the existing tile, and retile. I have some of the tile removed now. This is the only chance I will want to take to bust up this floor, but will gladly avoid it if there is no good reason for it. Welcome any thoughts and/or advice.
dgfit is offline   Reply With Quote
Old 12-05-2013, 11:25 AM   #2
K&B Designer
Live_Oak's Avatar
Are you talking an old fashioned mudbed with tile on top, or are you talking actual concrete floors?
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 12-05-2013, 11:49 AM   #3
Rewards Points: 294
It looks like concrete. You can see the area in this pic where I have broken up some of the tile. The open area is where the tub had been located
Old 12-07-2013, 07:34 AM   #4
Rewards Points: 294
Any thoughts?
Old 12-07-2013, 10:32 PM   #5
Rewards Points: 294
Old 12-08-2013, 12:06 PM   #6
Not so new
12penny's Avatar
Rewards Points: 522
Not sure why your thread hasn't been replied to.
Joe must be napping.
Hard to tell from here. Lots comes into play.
Is it cracked, sloped, flat etc.? My first thought
is to get rid the mortar bed, repair/update
any structure/plumbing/electric and install 3/4
advantech for subfloor.
But I'm not there.
12penny is online now   Reply With Quote
Old 12-08-2013, 09:43 PM   #7
Rewards Points: 294
I don't have the tile up yet but it seems to be in ok shape. But I think I have decided to take it up - why do it part way. I am also in the process of replacing all water lines, complete rewire and upgrade service (all with permits).
Old 12-14-2013, 09:39 AM   #8
K&B Designer
Live_Oak's Avatar
It's always better to take things back to the studs/joists and start over.
Old 12-14-2013, 12:31 PM   #9
Registered User
Rewards Points: 526
I agree... especially with older houses that tended to over-span the joists before building codes. Your joists may be fine for the loads or not; the water supply/drain line are run to the closest wall below (across the room pictured) telling me the span to the other joist-bearing wall may be greater; the total span may be 10-12'- if so- a 2x6 will span 8'11" if Doug-Fir #2 (20# load); http://publicecodes.cyberregs.com/ic...002_par017.htm
Which brings me to my point (finally)...you have a lot of weight on the joists (not counting bathroom fixtures- sink, toilet-) of materials;
1" reinforced regular weight concrete =12.5# per sq.ft.
1" plain lightweight concrete (1) = 8#
7/16" cementitious backerboard = 3#
Ceramic or quarry tile (3/4") on 1/2" mortar bed (1)= 16#
Ceramic or quarry tile (3/4") on 1" mortar bed (1) = 23#
1" mortar bed = 12#
1" slate (1) = 15#
3/8" marble tile = 6#
3/8" ceramic floor tile (1) = 4.7#
Pick yours and add them up- compare to span charts- remember to add P&L at 8#per sq.ft. attached below the joists.....
Gary
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Pro advice needed on concrete contract language toddmanqa Concrete, Stone & Masonry 0 03-22-2012 08:39 AM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 08:23 AM
