Advice On Bathroom Remodel - Kitchen & Bath Remodeling - Page 18 - DIY Chatroom Home Improvement Forum
Old 07-27-2015, 05:08 AM   #256
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,278
Try mixing up a tiny batch and then you'll be able to take your time with it.
Remember that it better to toss some thin set in the garbage than to make a mess or end up leaving a big hump on the wall because you rushed it.
Check about the 9 minute mark. He is applying thin set to the wall.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 07-27-2015, 05:34 AM   #257
Retired Moderator
Rewards Points: 7,174
A 6" drywall blade is the easiest for taping the seams===remember--keep it thin---very thin--
I highly recommend waterproofing the board--pay extra attention around the window
Old 07-27-2015, 06:36 AM   #258
Solidify's Avatar
Rewards Points: 834
How do make the tape does'tget dragged when I pass over with my knife, even after embedding it into the thinset I'vejust smeared. And with a 6" putty knife how to do the inside and outside corners?
Solidify is offline   Reply With Quote
Old 07-27-2015, 09:30 AM   #259
Solidify's Avatar
Rewards Points: 834
I wont touch the window becuse thats way too complicated for me. I'll probably have someone else do that.
Old 07-27-2015, 12:41 PM   #260
Solidify's Avatar
Rewards Points: 834
Once again, nowhere near perfect but I managed after calming down -_-
The Following User Says Thank You to Solidify For This Useful Post:
oh'mike (07-27-2015)
Old 07-27-2015, 01:54 PM   #261
Retired Moderator
You figured it out---
Before is gets to hard---run your knife (the 6" blade) over the seams to knock off any ridges---
Old 07-27-2015, 02:27 PM   #262
Solidify's Avatar
Rewards Points: 834
Advice on Bathroom Remodel
Just got done doing that. Good tip.
Old 07-27-2015, 02:52 PM   #263
Solidify's Avatar
Rewards Points: 834
What do you mean by this pugsy?
Old 07-27-2015, 03:13 PM   #264
Solidify's Avatar
Rewards Points: 834
Originally Posted by JazMan View Post
If you chose not to apply surface waterproofing on the main walls, it may not cause a failure. But the window and other vulnerable areas need it.
Ok that's good news. What areas would qualify as vulnerable and how would I waterproof them?
Old 07-27-2015, 03:45 PM   #265
123pugsy's Avatar
You said the video didn't show applying to the walls but it does show about the 9 minute mark.
Old 07-27-2015, 04:18 PM   #266
Solidify's Avatar
Rewards Points: 834
When I said it "doesn't show applying thinset to the walls" I didn't mean tiling. I meant I couldn't find a video illustrating how to tape the seams of the CBU with thinset.
But it's all done now. Thanks.
123pugsy (07-27-2015)
Old 07-27-2015, 04:33 PM   #267
123pugsy's Avatar
I knew you'd get it.
Basically, troweling on for tiles and smoothing over seams just comes to you after trying it a few times. It's about the same motion to do it. Just takes a bit of practice which you now have.
Keep up the good work.
Old 07-27-2015, 04:56 PM   #268
Solidify's Avatar
Rewards Points: 834
Thanks for the encouragement pugsy.
I'm just really stuck on whether to apply the RedGard. I didn't think it would be that expensive and this is a make-shift job in my opinion so I don't wanna pump much more money into it, especially considering I still need to but the tiles.
Old 07-27-2015, 05:24 PM   #269
Retired Moderator
I was surprised at what you must pay for the Red Guard---
The most critical area is the window---the area below it and the plumbing wall---
There are a number of good paint on waterproofing membranes--have you called around to see if your local stores offer something at a more reasonable price?
JazMan (07-27-2015)
Old 07-27-2015, 06:02 PM   #270
123pugsy's Avatar
Maybe I should take a walk next door and knock out some tiles for the good of everyone here to see what has happened in 9 years without any water proofing.
The wrecking ball comes tomorrow so this would be my last chance to investigate.
Bathroom Remodel - Need Advice adj83 Remodeling 6 10-24-2011 11:40 PM
The Bathroom Remodel that just kept growing... gpsmith Kitchen & Bath Remodeling 1 05-28-2011 05:25 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 07:28 PM
