Advice On Bathroom Remodel - Kitchen & Bath Remodeling - Page 15 - DIY Chatroom Home Improvement Forum
Old 07-21-2015, 07:33 AM   #211
Solidify's Avatar
Rewards Points: 834
Advice on Bathroom Remodel
"Before you fully screw in the last sheet, test the "flatness with a tile going up the seam just to be sure you won't have a bump."
Can you explain this a bit better? Sorry.
Edit: Nvm. So you mean test the flatness after i tape the seam with the thinset?
Solidify is offline   Reply With Quote
Old 07-21-2015, 07:50 AM   #212
Rewards Points: 186
Can you explain this a bit better? Sorry...
When you set your tile, you want the transition from old tile to new tile to be flat. If your backerboard is not in the same plane as the existing drywall, you'll wind up with a bump that will cause your tile to not lay flat on the wall. The bump (aka lippage) will occur because tile isn't flexible.
For example, If you take two tiles and lay them on a table top, they will be flat and when you run your hand over the joint, it will be flat. If you put something under one of the tiles, it will not lay flat.
I'm suggesting not fully screwing the board in at first because you may need to adjust it with shims to get the board flat with the existing drywall. It's easier to take out a few screws than many.
Dan
djlandkpl is online now   Reply With Quote
Old 07-21-2015, 08:22 AM   #213
Solidify's Avatar
Rewards Points: 834
Ok will do but then you're advising with my idea to scribe/cut the CBU to fit like a puzzle with the existing crooked drywall?
Old 07-21-2015, 08:57 AM   #214
Rewards Points: 186
Yes but you don't have to be super precise.
Dan
Old 07-21-2015, 09:02 AM   #215
Solidify's Avatar
Rewards Points: 834
Roger that, because I can fill the gap with thinset. Ok, I'll keep you all up-to-date.
Old 07-24-2015, 05:19 PM   #216
Solidify's Avatar
Rewards Points: 834
I made an extra cutout for the spout by accident. Can that be fixed?
Old 07-24-2015, 05:41 PM   #217
Rewards Points: 186
Fill it with thinset so you can waterproof it. A tile will likely span the hole.
Dan
Old 07-24-2015, 05:47 PM   #218
Solidify's Avatar
Rewards Points: 834
Is the tape for the seams that I'm supposed to be using the same fiberglass mesh tape used when doing the seams on regular drywall? A link to the product would be helpful.
Old 07-24-2015, 05:59 PM   #219
Rewards Points: 186
It's different. It's usually sold next to the backerboard / backerboard screws.
http://www.homedepot.com/p/QEP-2-in-...600Q/100645273
Dan
Old 07-24-2015, 06:17 PM   #220
Solidify's Avatar
Rewards Points: 834
How is that different from the mesh tape used for drywall? It looks exactly the same...
Drywall tape:
Name:  ImageUploadedByDIY Chat1437779872.233514.jpg
Old 07-24-2015, 07:01 PM   #221
Rewards Points: 186
I don't know for sure. Each brand is different. The drywall mesh may have adhesive. The backerboard tape may be alkali resistant.
Dan
Old 07-24-2015, 07:25 PM   #222
Solidify's Avatar
Rewards Points: 834
I have a good amount of the mesh drywall tape and was curious if I could use it. Even read quite a few forums attesting that nothing bad can come of this.
Old 07-24-2015, 07:38 PM   #223
Rewards Points: 186
I don't have the experience to say yes or no. At the end of the day it will be buried in thinset.
Dan
Old 07-24-2015, 07:41 PM   #224
Solidify's Avatar
Rewards Points: 834
Ok so I think I'll just use that. And for the waterproofind membrane, I still haven't decided which one to use.
What Are my options? I was thinking redguard with the roller but they all seem crazy expensive, nor would I know how much I need
Old 07-24-2015, 08:40 PM   #225
Rewards Points: 186
I've used both Hydroban and Redgard. Pretty much the same and both are expensive. Cheaper than having to fix a leak. You should be fine with one bucket.
Dan
Bathroom Remodel - Need Advice adj83 Remodeling 6 10-24-2011 11:40 PM
The Bathroom Remodel that just kept growing... gpsmith Kitchen & Bath Remodeling 1 05-28-2011 05:25 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 07:28 PM
