Advice On Bathroom Remodel - Kitchen & Bath Remodeling - Page 13 - DIY Chatroom Home Improvement Forum
Old 07-14-2015, 12:34 PM   #181
Rewards Points: 272
Originally Posted by JazMan View Post
Man, you're easy to convince.
I agree, go with a nice curtain set. It'll look much nicer and you may want to have a few so you can change the color theme with the seasons. Curved rod is nice, but may not look the best with some of the fancy outer drape curtain.
Jaz
When I am in the shower I (personally) don't care much about looks. Having the curtain hitting my elbows or being sucked against me by the draft created by the flow of water from the shower head creates more of a concern to me than the looks. Functionality over looks for me. Guess you are more into your feminine side than me.....just teasing you Jaz.
fixrite is offline   Reply With Quote
The Following User Says Thank You to fixrite For This Useful Post:
Solidify (07-14-2015)
Old 07-14-2015, 02:06 PM   #182
Tileguy
JazMan's Avatar
Rewards Points: 748
Yes, my feminine side. aka the wife! I swear she changes the bathroom decor 3 times a year.
I like the curved rods too. Only used one with it in hotels so far.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 07-16-2015, 07:52 PM   #183
Solidify's Avatar
Rewards Points: 834
Caved and had plumber do the hard stuff. 200$ and 5 hours later, the tub is in (leveled and shimmed), he put two shut offs behind the access panel and adjusted the drain and overflow to the new tub.
I just need to add a little more height wjth the thinset while putting the floor tiles.
Never calling this plumber again though; he cut so many corners. I guess that's why he only charged us 30$/hour.
Solidify is offline   Reply With Quote
Old 07-17-2015, 01:16 PM   #184
Solidify's Avatar
Rewards Points: 834
I just finished framing the back tub wall which doubles as a linen cabinet. I'm going to add another support in the middle so theres no flex with the cement board.
The only problem is that the entire wall is fastened to the exterior wall so I'd like to atleast be able to fasten it to the floor, which is deck mud now. I'd like to try to sink a couple of wood screws through the mud to catch the subfloor (and then maybe the ceiling wherever I can detect wood with my sud finder)... Will the former require concrete screws? Just asking because the sand doesn't seem that hard.
Old 07-18-2015, 12:57 PM   #185
Solidify's Avatar
Rewards Points: 834
Old 07-19-2015, 05:40 PM   #186
Solidify's Avatar
Rewards Points: 834
My framing was all off in relation to the CBU so I had to beef it up a bit:
Old 07-19-2015, 06:25 PM   #187
Rewards Points: 186
Before you cover up the framing, you may want to add blocking where the shower curtain rod will be hung if you are going for a non-tension rod. Also you may need additional blocking at the base of the tub for the backerboard to screw into.
Dan
djlandkpl is online now   Reply With Quote
Old 07-19-2015, 06:37 PM   #188
Solidify's Avatar
Rewards Points: 834
Advice on Bathroom Remodel
What is better: tension-rod or the ones that screw into the wall? I mean, those things aren't supposed to hold weight, just the shower curtains...
And by the "base of the tub" you mean right under the mixing valve?
Old 07-19-2015, 07:04 PM   #189
Solidify's Avatar
Rewards Points: 834
I can't put more than this because of the pipe:
Old 07-19-2015, 07:11 PM   #190
Retired Moderator
Rewards Points: 7,174
One plumbing note:
The tub spout----most plumbers use a threaded drop eared flange for the tub spout--
That is the same as the shower arm fitting---then screw that securely to the framing==
Add a stub out with a male fitting----just a suggestion so you don't have problems when you go to install the spout.
Old 07-19-2015, 07:14 PM   #191
Solidify's Avatar
Rewards Points: 834
Can't I just slide my tub spout over the pipe and secure it with the allen screw on the underside?...rather than screw it
Old 07-19-2015, 07:30 PM   #192
Rewards Points: 186
It's personal preference. I like the curved rods and they are more secure screwed in.
I mean the small section of wall that will be next to the bottom of the tub. When you hang the backerboard you'll need a place to nail/screw into
Dan
Old 07-19-2015, 07:48 PM   #193
Solidify's Avatar
Rewards Points: 834
ok for blocking. and ill give the rod some thought
Old 07-19-2015, 07:55 PM   #194
Solidify's Avatar
Rewards Points: 834
Originally Posted by oh'mike View Post
One plumbing note:
What exactly is a stub out with male fitting and how do I get it onto what there is now? I just checked and my tub spout is threaded.
Old 07-20-2015, 04:35 AM   #195
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,276
Throw away the threaded spout and get the slide on one with the set screw.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
Bathroom Remodel - Need Advice adj83 Remodeling 6 10-24-2011 11:40 PM
The Bathroom Remodel that just kept growing... gpsmith Kitchen & Bath Remodeling 1 05-28-2011 05:25 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 07:28 PM
