Advice On Bathroom Remodel - Kitchen & Bath Remodeling - Page 12 - DIY Chatroom Home Improvement Forum
Old 07-09-2015, 03:27 PM   #166
Solidify's Avatar
Rewards Points: 834
Also, I have two low voltage leads from removing my wall radio. How do I take care of this safe/by following code?
I tried tucking them away as nicely as possible but I don't think that will do it.
Solidify is offline   Reply With Quote
Old 07-09-2015, 07:26 PM   #167
Tileguy
JazMan's Avatar
Rewards Points: 748
If you're gonna remove them just find the source and take them out. If keeping them, remove the staples to make room for some new lumber. The new sister doesn't have to be a 2x4.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 07-09-2015, 08:03 PM   #168
Solidify's Avatar
Rewards Points: 834
Ok yes but even with the new sister stud, what should I do with the wires if I'm keeping them? I just staple them as is but to the new sister stud?
Old 07-09-2015, 08:13 PM   #169
Solidify's Avatar
Rewards Points: 834
I had to relocate a stud that fell right where the shower arm's pipe is to be installed:
Before:
After:
Old 07-09-2015, 08:56 PM   #170
Tileguy
JazMan's Avatar
Rewards Points: 748
It looked fine as it was, but ok an extra stud is good. Did the drywall get messes up much?
Jaz
Old 07-09-2015, 09:27 PM   #171
Solidify's Avatar
Rewards Points: 834
Advice on Bathroom Remodel
No the drywall on the other side didn't get damaged. When I pulled the wood out, it ripped the drywall screws right out of the drywall without any damage so I was lucky. Then I just added two new studs to be able to fasten the wood brace for the shower arm that's going to be 76" high, as per Moen's installation instructions.
Old 07-10-2015, 10:14 AM   #172
Solidify's Avatar
Rewards Points: 834
We had a friend come by that is a carpenter and he was telling me that the tub doesn't need to be waterproofed because the tile and grout don't let the water in.
I'm not sure if it has to do with the fact that he's 70 something years old and hasn't gotten with the times...
He was even telling me that I can use regular drywall behind the shower tiles and don't need to plaster the joints with drywall compound because the tiles will be over them.
Old 07-10-2015, 10:44 AM   #173
Tileguy
JazMan's Avatar
Rewards Points: 748
That's great!!
What does your barber have to say?
Jaz
Old 07-10-2015, 10:47 AM   #174
Solidify's Avatar
Rewards Points: 834
Lol i didnt say i agree.. I just wanted to point out how absurd some people are
The Following User Says Thank You to Solidify For This Useful Post:
JazMan (07-10-2015)
Old 07-13-2015, 10:29 PM   #175
Solidify's Avatar
Rewards Points: 834
Should I install a bathtub door or curtain on a rod?
Edit: I guess that's just preference so nevermind, although your comments are still welcome.
Old 07-14-2015, 06:49 AM   #176
Rewards Points: 107
I prefer a curtain. Doors make it harder to clean the tub and the doors themselves need to be cleaned. If anyone in your takes baths, the doors make kind of a confining industrial atmosphere in my opinion. Better to move the curtain out of the way
jimn01 is offline   Reply With Quote
Old 07-14-2015, 08:12 AM   #177
Solidify's Avatar
Rewards Points: 834
Ok, good call. We'll go with the curtain and rod.
Old 07-14-2015, 08:16 AM   #178
Rewards Points: 272
Just a suggestion, I would install a curved curtain rod. It allows you more room when showering, and keeps the curtain away from you. Just a suggestion....
fixrite is offline   Reply With Quote
Old 07-14-2015, 09:30 AM   #179
Tileguy
JazMan's Avatar
Rewards Points: 748
Man, you're easy to convince.
I agree, go with a nice curtain set. It'll look much nicer and you may want to have a few so you can change the color theme with the seasons. Curved rod is nice, but may not look the best with some of the fancy outer drape curtain.
Jaz
Old 07-14-2015, 10:04 AM   #180
Solidify's Avatar
Rewards Points: 834
Haha yea, but it helps knowing the doors start at 200$ and the curtain would be far cheaper
A curtain is also easier to install and doesnt require me to add framing that would be used to fasten the door to
Bathroom Remodel - Need Advice adj83 Remodeling 6 10-24-2011 11:40 PM
The Bathroom Remodel that just kept growing... gpsmith Kitchen & Bath Remodeling 1 05-28-2011 05:25 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 07:28 PM
