Advice On Bathroom Remodel - Kitchen & Bath Remodeling - Page 11 - DIY Chatroom Home Improvement Forum
Old 07-08-2015, 05:59 PM   #151
Solidify's Avatar
Rewards Points: 834
That's what we were going to do. A linen cabinet. I guess I'm just too far discouraged by the way things are looking that I'm putting the issues under the microscope.
Solidify is offline   Reply With Quote
Old 07-08-2015, 06:20 PM   #152
Solidify's Avatar
Rewards Points: 834
Question: How would I even fasten the CBU to this stud?
Old 07-08-2015, 06:24 PM   #153
Tileguy
JazMan's Avatar
Rewards Points: 748
Come on now....... count to ten, then think about it. English or French will do.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 07-08-2015, 06:33 PM   #154
Solidify's Avatar
Rewards Points: 834
I've been staring at these walls for too long. Spare me...
Old 07-08-2015, 06:50 PM   #155
Tileguy
JazMan's Avatar
Rewards Points: 748
Don't take offense, I'm just a born wise guy.
OK, so that's the wet wall on the right. Just trim the wallboard so it ends on the center of the stud.
Jaz
Old 07-08-2015, 10:11 PM   #156
Solidify's Avatar
Rewards Points: 834
Even if i were able to do that, I'd still have mastic on the old drywall making the mating surface uneven.
Old 07-09-2015, 09:06 AM   #157
Solidify's Avatar
Rewards Points: 834
Not to mention it would be very difficult to tape the seam between the new and old drywall/CBU.
Old 07-09-2015, 10:13 AM   #158
Tileguy
JazMan's Avatar
Rewards Points: 748
Well, what's the answer then, do nothing? You'll need to scrape and or sand the area?
....And that's why you normally have to remove an extra row of tiles to be able to prep the area. You learned that on the floor you just tried to do.
Jaz
Old 07-09-2015, 10:22 AM   #159
Solidify's Avatar
Rewards Points: 834
Advice on Bathroom Remodel
Jaz
yea but think about it, even if i remove another row of the old tile to have more room to prep the old drywall for mating with the new CBU, id still have to sand/scrape the mastic off the okd drywall right flush up until the old tile begins.... Gosh
It seams like like u find a lose thread in ur shirt and u pull it to remove it and eventually u pull the whole shirt apart...
Old 07-09-2015, 10:41 AM   #160
Tileguy
JazMan's Avatar
Rewards Points: 748
Well, of course, and in this case you shouldn't have to do that. (remove another row to gain room to tape). That's what we were talking about, the tape, it's pretty obvious you need to remove the old mastic. Keep the yellow pages near.
Jaz
Old 07-09-2015, 10:45 AM   #161
Solidify's Avatar
Rewards Points: 834
Two questions:
1. How do I cut the drywall leaving half of it on the stud if I can't get my drywall knife in there because the wood is behind it? I tried scoring it with my sharp utility knife but it's really difficult to make it all the wall through to the wood.
2. What would be the easiest way to sand or remove the mastic of the old drywall?
I'm also worried that half a stud wont be much room for error when Im going to need to screw the CBU screws into the wood (same in terms of relocating the old drywall screws on the half stud)
Old 07-09-2015, 10:59 AM   #162
Tileguy
JazMan's Avatar
Rewards Points: 748
I recall several years ago someone started a thread to help rip out and re-build a shower. After receiving some advice, he asked if someone could tell him what a "trowel" was. I mean really? Get the checkbook.
Jaz
Old 07-09-2015, 11:10 AM   #163
Solidify's Avatar
Rewards Points: 834
Jaz, might I remind you that it was you that told me that you've helped people with few skills accomplish projects and urged me to continue asking questions. And now that I've taken to doing just that you seem to be scorning at the fact that I'm asking stupid ones.
I think my questions are a bit more complex than asking what a trowel is. I'm presenting you a problem I'm facing and detailing you the issue as best as I can.
You're under no obligation to continue helping me if you feel that way. This is a forum, not a dialogue.
Old 07-09-2015, 11:22 AM   #164
Tileguy
JazMan's Avatar
Rewards Points: 748
How about you score it a second time, and then a third?
Try sandpaper and/or a scraper.
How do you think drywall and CBU are joined in the first place? You've got " to play with so you start the fastener near the edge and drive it with a slight angle towards the center. Or, you can simply fasten a sister or blocks to the stud and leave the panel as is.
Jaz
Old 07-09-2015, 11:27 AM   #165
Solidify's Avatar
Rewards Points: 834
Ok thanks. I think I'll fasten a sister stud
Bathroom Remodel - Need Advice adj83 Remodeling 6 10-24-2011 11:40 PM
The Bathroom Remodel that just kept growing... gpsmith Kitchen & Bath Remodeling 1 05-28-2011 05:25 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 07:28 PM
