Advice On Bathroom Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-18-2015, 11:45 AM   #1
Solidify's Avatar
Rewards Points: 834
Advice on Bathroom Remodel
We have a 72 inch tub in our main washroom. House was built in 1972 so the tiled step that was used to step up into the tub had a bunch of broken/severed tiles, so we decided we'd fix it. The problem is, we don't exactly know what we're looking to do, yet.
The shower has never had a curtain or a shower door, so we never used it for the shower, we only took baths there (not to mention the showerhead was installed 4 feet off the wall for some reason). The lack of a door or curtain is probably what severed the tiles around the tub.
We started demo-ing and this is what's left. The tub is big, no doubt. But even if we downsize, we still wouldn't have a back support to put a shower door (since it would need something to be fastened to). We were thinking of making a cabinet for towels etc. in the left corner which would double as a support for a shower door.
What would you guys do? We're open to all suggestions. We demolished before thinking this through. We just don't wanna renovate the entire washroom because we just don't have the money for that. We're thinking the bidet will be removed also to add some leg room.
Advice on Bathroom Remodel-img_1206.jpg   Advice on Bathroom Remodel-img_1207.jpg   Advice on Bathroom Remodel-img_1218.jpg   Advice on Bathroom Remodel-img_1219.jpg   Advice on Bathroom Remodel-img_1220.jpg
Solidify is offline   Reply With Quote
Old 06-18-2015, 11:47 AM   #2
Solidify's Avatar
Rewards Points: 834
Old 06-18-2015, 03:21 PM   #3
Rewards Points: 454
If I am understanding you right. just frame a wall in back of the tub. leave it open and you could put some shelves in it or a built in. and you could not run the wall all the way to the ceiling and make the top of the wall a shelf
You could also go with a one piece shower or one that has the tub and wall panels separate, the one piece tub is what I would do,
scottktmrider is offline   Reply With Quote
Old 06-18-2015, 03:32 PM   #4
Solidify's Avatar
Rewards Points: 834
Ok and lets say i wanted to downsize to a normal 60" tub, would i just remove the old tub and put the new one or would i have to raise the floor under the new tub so the tile ill reinstall will be flush with the old tile?
Old 06-18-2015, 03:47 PM   #5
Solidify's Avatar
Rewards Points: 834
And also, i think because this is an older home the tiles were put down directly with concrete or something:
Advice on Bathroom Remodel-imageuploadedbydiy-chat1434660381.330670.jpgAdvice on Bathroom Remodel-imageuploadedbydiy-chat1434660400.650747.jpg
Old 06-18-2015, 03:51 PM   #6
Solidify's Avatar
Rewards Points: 834
In other words, theres no underlayment. Its just these thin planks (probably 3/4" x 7") nailed directly to the rafters. Then they just dropped concrete onto that (genereously so it would raise the level) and tiled directly onto that.
Old 06-18-2015, 08:59 PM   #7
Retired Moderator
Rewards Points: 7,174
That old tile job is a mud bed---not well done---but a bed of 'deck mud' none the less--
You said that the budget is thin this week--so you will be doing a 'perfume the pig' job on the floor.
Build up layers of plywood topped with 1/4" cement board--what ever combination matches the height needed---then add your new tub---frame it with 2x4s and Durrock the walls.
Honestly, it will take some more time--but little more money, to demo the old floor --add plywood and backer and retile the entire floor---If you remove the bidet, you will have another patch in the old tile---
A few more details will help--Mike--
Old 06-18-2015, 09:49 PM   #8
Solidify's Avatar
Rewards Points: 834
How was that mud bed supposed to have been done?
Old 06-19-2015, 05:14 AM   #9
Retired Moderator
Typically, tar paper over the subfloor ,then expanded steel mesh, then the mud--
You could try that--the old sub floor doesn't look very well done---big gaps---
Old 06-19-2015, 06:00 AM   #10
Solidify's Avatar
Rewards Points: 834
Thats exactly how I found it when demoing.
Old 06-19-2015, 06:18 AM   #11
Retired Moderator
You could try your own mud bed---here is a link to shower pan building--it has a good description of deck mud---How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
Mixing it to the damp beach sand stage is the key---it is remarkably stable when set--
Old 06-19-2015, 10:14 AM   #12
Solidify's Avatar
Rewards Points: 834
The more I keep thinking this project over, the more I start realizing that I should just hold off until I can afford to renovate the entire bathroom, to avoid a Frankenstein-looking end result.
The Following User Says Thank You to Solidify For This Useful Post:
oh'mike (06-22-2015)
Old 06-20-2015, 01:31 AM   #13
Rewards Points: 454
Sounds like the best, first off you need to decided on all your fixtures, tub,wall coverings etc.the floor should be one of the last things you do.and if your going to be putting a tile floor you should have a level even floor with duraroc down, you can't just throw tile down to cover the ugly floor up.or your tiles will be breaking.
Old 06-21-2015, 09:16 PM   #14
Solidify's Avatar
Rewards Points: 834
We decided on replacing the tub with a 60", raising the showerhead and putting a cabinet in the back to support the future shower door. I got the tub loose today but its easily a couple hundred pounds and it's difficult to maneuver it to get it out of the washroom. So tomorrow I'm going to temporarily cap the bidet's hot and cold line with shut off valves so we can thrash that bidet (which we were just planning to do later) which will make it so the tub can clear the washroom. We spent a good hour and a half today trying to get it out but it's just too heavy and too awkward.
Progress:
Advice on Bathroom Remodel-img_1466.jpg   Advice on Bathroom Remodel-img_1467.jpg
Old 06-22-2015, 06:03 AM   #15
Rewards Points: 582
make sure you look at repairing that joist that is cut in half...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Bathroom Remodel - Need Advice adj83 Remodeling 6 10-24-2011 11:40 PM
The Bathroom Remodel that just kept growing... gpsmith Kitchen & Bath Remodeling 1 05-28-2011 05:25 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 07:28 PM
