Adhesive For Small Piece Of Tile? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By JazMan
Old 12-22-2016, 06:40 PM   #1
Rewards Points: 1,176
Adhesive for small piece of tile?
I have 2 small pieces of tile to (5" x 6") to install on the left and right side of the outside of the shower curb
What kind of adhesive can I use if I don't want to mix thinset for such small pieces?
french_guy is offline   Reply With Quote
Old 12-22-2016, 07:11 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,242
Re: Adhesive for small piece of tile?
Do you have any left over thinset? Shouldn't be hard to mix a tiny batch. Mastic is moisture sensitive and will not fare well.
Old 12-22-2016, 08:35 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 748
Hi Frech Guy,
In the home stretch I see. Thinset would be best if what you may have isn't too old or wasn't opened and you kept it in the garage or on the basement floor. In a pinch regular caulk will work just fine for this purpose. How about the grout? Do you have any caulk to match the wall grout used in the shower? Could use that too.
Jaz
Merry Christmas Everyone
Windows on Wash likes this.
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 12-23-2016, 11:19 AM   #4
I have some thinset (Versabond) from this summer. Bag was opened, and wrapped into a plastic bag, and store into the garage
I do have some grout left as well, and also the acrylic caulk that matches the grout color
I was thinking to use some construction adhesive for the tiles, but if mixing a small qty of thinset is much better, i guess I can do that...
Old 12-23-2016, 11:32 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 748
Maybe you should re read my suggestion? But it might still be ok. The caulk may be ok if manufactured this year.
Jaz
Old 12-23-2016, 11:35 AM   #6
So 6 months old thinset - opened - is too old?
Old 12-23-2016, 12:08 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 748
There's no way to know for sure. It has a shelf life of 12 months from the day it was made, not bought, IF it is unopened and stored in a conditioned space. Some would say 2 weeks after opening and stored in a garage is questionable.
12-24 months is an industry norm. I didn't check to see what Custom has to say, but once opened and stored in your garage I wouldn't use it on your job. But for those two pieces.....who cares.
Jaz
linoleum and adhesive removal, tile after dave.vp Flooring 0 11-15-2012 11:58 AM
Can I use tile adhesive over old mortar to fix loose tiles? JFERTICH Flooring 1 10-13-2012 10:20 PM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Completely remove vinyl adhesive before tile? JetSetEng Flooring 2 04-19-2012 05:47 AM
Newbie to 1950's house - tile adhesive removal? FixyChik General DIY Discussions 20 01-08-2009 09:34 AM
