Adding A New Bathroom - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 02:02 PM   #16
Rewards Points: 312
Originally Posted by Dairylander View Post
I wanted to know if you were up North like me. We avoid putting plumbing in any exterior wall because pipes can freeze and burst.
If you're going to have two people in there at a time, then the pocket door will be even more useful.
Two pedestal sinks will use up a lot less space than a double vanity cabinet. (but they offer no storage)
You could rotate the tub 180 degrees so the plumbing is on the same wall as the door.
Raise the window up toward the ceiling or use a shorter window.
Then you could move the sinks West several inches to give better access.
Hence I am from west, I can do plumbing on exterior wall, though I don't prefer to break the existing wall. Except that wall, rest all going to be new walls, so it is always better to add pluming to existing walls.
next, I can move the sink to north side so that, as you said, plumbing can be done to the door wall. Then I will have 1ft space on the winow side wall, which is exterior wall.
Based on Home depot, the shortest window would be 17", but I thought that would be too narrow. In fact, I don't necessarily need a window since I am going to have an exhaust fan. But it adds some value to the bathroom.
cprao is offline   Reply With Quote
Old 02-21-2010, 02:03 PM   #17
Rewards Points: 312
Originally Posted by Bud Cline View Post
Entry from the North!!!!
Through the window????
What does this mean ?
Old 02-21-2010, 02:08 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well, I was looking at the drawing and I think the drawing has a notation (in the upper left corner) that the entry is from the north.
THEN, there is also a north-arrow represented. This arrow points to the right of the page where the window is. From what I remember seeing the door (entry) was to the left of the page (south). Not sure now what I did see.
XXX
Old 02-21-2010, 03:33 PM   #19
Natural light is extremely valuable.
How high are your ceilings?
Dairylander is offline   Reply With Quote
Old 02-21-2010, 04:22 PM   #20
Rewards Points: 312
9 foot ceiling.. 1970 Construction.
Old 02-21-2010, 05:09 PM   #21
Then you may have enough space to install a transom style window above the sinks up high by the ceiling, and still have enough wall space below it for a medicine cabinet or mirror.
Something like these:
http://homebuilding.thefuntimesguide...oom_shower.JPG
http://www.vrankovillage.com/rennova...671-733648.JPG
Old 02-21-2010, 05:11 PM   #22
Rewards Points: 312
Also looking online for double sink vanities.. Most of them are look like 72" inch wide, 6 ft.. which does not fit to my design. I am sure either I need to change the design or change the intent of having double sink vanity.
How about if I move sink to right side of the entrace by taking off the toilet. In that case, both of my tub and vanity will be facing each other.
Then move the toliet infront of the door and underneath the winow.. Though I don't like this idea of having toilet right infont of the door.
Old 02-21-2010, 05:37 PM   #23
A 6x9 bathroom generally doesn't allow a double vanity. Two pedestal sinks may squeeze in there, otherwise search for an 18 inch deep double vanity. Very rare, but just what you need.
I agree, don't do that.
Old 02-21-2010, 06:27 PM   #24
Rewards Points: 312
Ok.. Got you.. good idea.
If that is the case, I can put 72 " vanity on the exterior side wall.
so 2.5 ft width of tub + 6 ft windth of vanity = 8.5 ft.. I have total 9 ft..
I probably extend the width of the bathroom to 9.5 so that one foot gap is maintained between tub and vanity.
Toilet can be where it is now..
Only hitch is - I have to open the exterior wall to run plumbing..
Let me flip things on the paper and see how does it look like..
Here is the modified one..
http://i699.photobucket.com/albums/v...roomdesign.gif
Old 02-22-2010, 04:02 AM   #25
I didn't notice this before, but you have the vanity depth labeled as 2.5 feet, which is 30 inches.
Standard vanity depth is 21 inches plus an inch for sink/counter overhang, so it should be 22 inches.
Old 02-22-2010, 08:51 AM   #26
Rewards Points: 312
That is good. I save couple of more inches here.. I will change the design to match this..
How about standard toilet dimensions ?
Old 02-22-2010, 10:46 AM   #27
It will depend on whether you have a 10" or 12" rough-in and whether you go round or elongated bowl.
Small - 20"x28"
Big - 22"x34"
Your county will have code requirements for how much space you need around the toilet.
Old 02-22-2010, 07:13 PM   #28
Rewards Points: 312
Small - 20"x28"
Big - 22"x34"
I guess with the new design, either of the size will fit into the room nicely.
Old 03-12-2010, 06:16 PM   #29
Hi, we're adding a new bath also, actually we're removing one and replacing it with two. I couldn't make out the dimensions on your plan (bad eyes) but I found www.nkba.org (National Kitchen and Bath Association) invaluable in planning ours, especially the section on clearances (i.e. side clearance for toilets: 15" from center minimum, 18" recommended). Every example is clearly illustrated, and it answered all my numerous questions about bath layout.
NCgranny is offline   Reply With Quote
Old 03-12-2010, 08:19 PM   #30
Rewards Points: 312
Ok. Thank you for thr info... I will look into this..
Adding a Second Floor Bathroom in Iowa Iowa DIYer Plumbing 1 12-26-2009 02:38 AM
plumbing/septic tank connection for adding a second bathroom mrbowma Plumbing 2 08-03-2009 04:51 AM
adding a bathroom browneyedsusie Plumbing 2 07-30-2009 11:18 PM
Newbie looking for any help and info that I can get on adding this bathroom.... iwtmkc Kitchen & Bath Remodeling 3 12-12-2008 02:10 PM
Adding a bathroom DDRowe Building & Construction 3 05-28-2005 06:51 AM
