Acrylic Tub Flange - Uneven Gap - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-13-2014, 12:13 PM   #1
Rewards Points: 54
Acrylic tub flange - uneven gap
I am installing an acrylic tub in a bathroom remodel. The tub will need a shim on one end to meet the opening. No big deal there. But I have another issue.
The gap over there is not even. It starts at about 7/16" and at the top is 5/8". So the main shim will have to be cut from 7/16 plywood. This is the flange on the drain side, attached to the tub skirt.
But what can I do about the gap at the top? I am afraid that the tub will crack if I try to flex it in that far. I was considering using a heat gun on a low setting to soften and move that flange a little more in line. Would this work or will it damage the acrylic?
Thanks in advance.
SC Tiger is offline   Reply With Quote
Old 10-13-2014, 04:39 PM   #2
Retired Moderator
Rewards Points: 7,174
Is the wall out of whack or is it the tub?
Typically--if the wall studs are out of line--adding (sistering) extra studs along side the existing ones will take care of that problem--
Old 10-14-2014, 07:52 AM   #3
Rewards Points: 54
Turned out to be a non issue. When I put the shim in the entire flange went in line.
But apparently I didn't level the tub right because the surriund isn't going on right. Looks like I'm redoing it again.
The Following User Says Thank You to SC Tiger For This Useful Post:
oh'mike (10-15-2014)
Three questions about acrylic tub flange will83 Kitchen & Bath Remodeling 0 08-12-2013 08:26 AM
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Installing flange over uneven drain pipe cburke517 Plumbing 5 07-30-2012 04:40 PM
replace uneven toilet flange? Samw09 Plumbing 1 11-15-2009 08:41 PM
