2ea. Bathroom Venting - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-05-2016, 07:33 PM   #1
Rewards Points: 40
2ea. bathroom venting
Nah not going to beat the ventilation dog again, but here is a twist ?
Remodeled both baths in my condo. Both vented to the outside
separately with metal duct above in attic. I disassembled ducts,
installed insulation sleeves to all tubes. (condensation issue)
Now picture a big "Y",. . top is from baths which now meet at a wye, combining into one duct, travel 15ft. as one then go to the
outside thru exhaust flapper.
installed additional baffles at inlets to wye, to reduce possible siphon,
and vacuum. (overkill that's me)
Anyway, I have now connected two baths to a trunk line.
LEGAL? ?? Code says ??
I've seen motels feed to a common trunk line of the same size.
I snitched the one, now extra duct to handle a kit hood vent!
I'm in Michigan . . . . . . and its snowing !
whats the verdict?
THANKS
Scout10 is offline   Reply With Quote
Old 04-05-2016, 08:02 PM   #2
Rewards Points: 258
Re: 2ea. bathroom venting
if you have one fan pulling the main line its good, if you have fans in each bathroom pushing into a combined vent no good, as you can force the air from one bathroom into the other..
woodchopper65 is offline   Reply With Quote
Old 04-05-2016, 08:31 PM   #3
Rewards Points: 40
Okay . . . both baths have power lite/vents which come with built in
baffles to prevent back flow. and the feed duct from each to wye
also has a baffle. thus my overkill.
A baffle is standard on all bath power vents from box stores.
Old 04-05-2016, 08:41 PM   #4
Rewards Points: 17,890
Should have two different lines, two different roof or outside wall vents.
couple questions about venting for basement bathroom ponch37300 Plumbing 1 02-01-2015 12:28 PM
Basement Bathroom Venting Beepster Plumbing 5 11-24-2014 09:44 AM
bathroom venting Zmulle3 Plumbing 11 09-17-2014 08:47 PM
Bathroom Fan Venting Question elliotriley Roofing/Siding 5 03-26-2012 08:23 PM
Bathroom Remodel Venting JPWMU Plumbing 0 05-16-2011 08:23 AM
