2" ABS Pipe Thru' 2x4 Stud (non-bearing) - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-13-2014, 01:11 AM   #1
Rewards Points: 417
2" ABS pipe thru' 2x4 stud (non-bearing)
Hi,
Need to change location of toilet in bathroom so need to run ABS pipe thru' stud.
Is it ok to run a 2" ABS pipe thru' 2x4 stud (non-bearing)?
60% of 4" stud width (actual size 3 1/2") is around 2 1/8", but the OD of 2" ABS is 2 3/8". It's 1/2" short.
Do I need to upgrade to 2x6 studs to run 2" ABS pipe? Or it'd still pass inspection?
Thx.
joemc3 is offline   Reply With Quote
Old 10-14-2014, 11:02 AM   #2
Rewards Points: 54
Originally Posted by joemc3 View Post
Hi,
Thx.
Not an expert but two questions - I assume this is the freshwater line:
1) Do you have to run it through a stud? On my current bathroom project I moved the cold water to the tub and just re-drilled the floor. Wasn't hard.
2) Why 2" pipe? My feed is 1/2" (5/8" OD) copper line.
SC Tiger is offline   Reply With Quote
Old 10-14-2014, 12:22 PM   #3
Rewards Points: 454
I take it your talking about a vent stack not a supply line?
scottktmrider is offline   Reply With Quote
Old 10-14-2014, 02:33 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Never mind.
sublime2 is offline   Reply With Quote
Old 10-14-2014, 06:39 PM   #5
Rewards Points: 122
OD of 2" abs is as you say 2.38", you would probably drill a 2.5" hole to route pipe. That would leave you 0.5" on each side of a 2x4. If it was me, I would use the 2x6 and cover with nailing plate to protect against a nail or screw penetrating the pipe.
Hidyi is offline   Reply With Quote
Old 10-14-2014, 07:03 PM   #6
Rewards Points: 454
Originally Posted by sublime2 View Post
Never mind.
Look at post #2
Old 10-15-2014, 12:22 AM   #7
Rewards Points: 417
2" ABS vent pipe thru' 2x4 stud (non-bearing)
I'm swapping the toilet location w/ the bathroom sink location, and it's the new 2" ABS vent pipe for the new toilet location I'm talking about.
There'd be a 1 1/2" ABS vent pipe for the swapped bathroom sink.
These two vent pipes would merge inside the wall, and a single vent pipe would go up to the attic and thru' the roof.
I'll need to merge the new 2" vent pipe back to the old galvanized vent pipe location (this is a 55 yrs old house) that's why it needs to go thru' the studs.
Another way perhaps, so don't have to change out the whole wall to use 2x6 studs instead?
Old 10-15-2014, 07:12 AM   #8
Rewards Points: 1,602
Could the vents pipes both go separately into the attic and then combine there? Would that allow you to just run them straight up in the stud bay and not go through the studs?
mikegp is offline   Reply With Quote
Old 10-15-2014, 10:32 AM   #9
Rewards Points: 82
Not sure about how correct it is, but I have a similiar issue with my venting, and I am going to run it horizontal outside the wall and box it in with a bulkhead instead of going through the 2x4's. Might look a little odd, but I don't want to jeopardize the wall or beef it up and noone will be the wiser. So this might be a secondary solution to think about.
grendel5269 is offline   Reply With Quote
Old 10-15-2014, 12:06 PM   #10
Rewards Points: 417
There are bathrooms on both sides of the wall. Toilets and sinks/medicine cabinets on both side of the walls.
So can't run the vent pipes outside the wall.
Old 10-15-2014, 06:05 PM   #11
Can you run them separately up into the attic?
pvc drain pipe in concrete debiasio Plumbing 8 12-06-2013 10:31 PM
Metal stud weight bearing capacity Alinerica Building & Construction 1 09-04-2013 08:59 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 07:49 PM
Bestion solution for insulating a 2" hot water pipe ? Wookai HVAC 14 01-15-2009 06:59 PM
