15 Inch Space Allowance For Toilet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 04:12 PM   #1
15 inch space allowance for toilet
Ok here's the deal. I know that there is code that dictates a minimum of 15" clearance between center of toilet and vanity/tub Etc... I want to put a new 30" vanity in, but that leaves me only 14 1/2".... Should I get something smaller to comply? If I go with the 30" vanity is an inspector going to make me change it when I sell my house?
Another quick one.. Do they make mold resistant and water resistant 1/4" green board? I've only been able to find it in 1/2....
X10012 is offline   Reply With Quote
Old 07-08-2012, 04:25 PM   #2
the Musigician
DangerMouse's Avatar
I think you have it wrong. 2006 International Plumbing Code - the clearances on both sides is 18" from the center of the bowl. The 2003 UPC mandates 24 inches clearance from the front lip of the bowl to any obstruction. The 2003 IPC (International Plumbing Code) mandates 21" minimum from the front of the bowl to any obstruction.
Of course, I could be wrong too.
DM
Old 07-08-2012, 05:21 PM   #3
This is what I was going off of as far as info...http://publicecodes.citation.com/ico...?bu2=undefined
Again not sure if it's the correct place to be looking though..
Old 07-08-2012, 05:33 PM   #4
the Musigician
Is this your home? New construction? Permits pulled? If not new, and it was already that close, I wouldn't be too concerned as it can be "Grandfathered" in. If new, it should have been thought out a bit better....
DM
Old 07-08-2012, 07:41 PM   #5
It's my place, small bath renno, no permits.... I'll get a vanity that will give me the clearance. Probably the best idea.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
Space between tiles and where to put the cut tiles thomascreen Tiling, ceramics, marble 1 09-19-2010 03:13 PM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
1 1/2 inch zone valve - can't find BOUTYM HVAC 2 11-20-2008 10:03 AM
