Zoeller Sump Pump Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2016, 10:03 PM   #16
Rewards Points: 190
Re: Zoeller sump pump repair
Thanks everybody, appreciate it. :-)
ogandou is offline   Reply With Quote
Old 03-15-2016, 05:55 AM   #17
SHEPLMBR's Avatar
Rewards Points: 178
Originally Posted by ogandou View Post
Yeah, I think you're right and I'm going to do that - but not right now because I need a lawn mower more than I need a shiny new pump at the moment, that's why I'm trying to just fix this one for now...
When I do, is it worth it to splurge on the next model up (M98)? I think it's 1/2 HP vs 1/3 HP (which is what I have right now). Since our sump never fills very fast I'm thinking maybe another M53 might be enough... but I'm wondering if I should also get an actual radon cover? A contractor installed a radon mitigation system for the previous owner and sealed the sump with a plexiglas cover with opening for the pipes. It works I guess, but it makes servicing the pump a total pain because I have to remove all the silicone sealant every time, then replace the silicone, etc...
Getting a bigger pump is not always a good idea. These pumps are designed to run. If short cycled enough they will burn out a lot quicker. Think of it as a rubber band. You stretch it out for longer periods of time and release. But if you are constantly stretching it out repetitively and quickly it wears out quicker.
SHEPLMBR is offline   Reply With Quote
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 10:42 PM
understanding the numbers on a sump pump and which one to buy ksimpson Plumbing 0 09-09-2011 07:51 AM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 06:51 PM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 05:26 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
