Zoeller Model#264 Install Question.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2015, 12:47 PM   #1
Still Decompressing
Rewards Points: 277
I am putting the final touches on my basement bathroom project, and am replacing the existing sump pump with a Zoeller #264 sewage pump. I was researching information on pump installations and had a questions. I see some folks drill a 3/16" hole on the pvc pipe a couple inches above the pump houseing to prevent air lock. I did a little more research and found that some Zoeller pumps have the small hole already drilled into the pump housing eliminating the need for the hole.
I do not see the hole anywhere obvious in my model #264 .4hp pump.
I did not see any installation instructions in the box, and don't see any on the Zoeller site.
I am leaning towards drilling the 3/16" hole 2-3" above the housing on the 2" PVC.
Any thoughts???
caveeagle is offline   Reply With Quote
Old 01-25-2015, 12:57 PM   #2
Civil Engineer
Rewards Points: 5,246
The hole is generally drilled in the pipe just upstream of the check valve. I have always been told that the purpose of the hole is to allow water in the pipe upstream of the check valve to drain back into the sump pit when the pump shuts down. This prevents freezing of water in the lines in cold climates. Typically I have seen a 1/8 inch diameter hole, but 3/16 should work too. Hole is typically drilled on underside of pipe within the sump pit, so water that sprays out during pumping stays in the pit.
I removed the check valve from my installation because it seemed to cause a lot of problems. I also operate with no pinhole in the pipe. Due to the pipe arrangement, this means that about 15 feet of pipe water drains back into the sump pit after each pumping cycle, but you would get the same thing if you had a hole in the pipe upstream of the check valve. My arrangement has worked out fine for the past fifteen years.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
caveeagle (01-25-2015)
Old 01-25-2015, 02:38 PM   #3
Rewards Points: 1,938
http://www.zoellerpumps.com/en-na/pr...-264#documents
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 01-25-2015, 05:07 PM   #4
Still Decompressing
Rewards Points: 277
Thanks for the link. I was using my old laptop with the older internet explorer and the 'documents' did not open up earlier when I was looking.
Using chrome, it opened up fine.
So, Zoeller says to drill the 3/16" hole in the discharge pipe even with the top of the pump. Inside the sump. I am using the cast iron Zoeller check valve that is above the sump about ~12" above the sump cover.
Old 01-25-2015, 09:05 PM   #5
Yep. Have fun.
Wiring question for wifi thermostat install speedster1 HVAC 7 10-30-2014 10:50 AM
Ceiling fan install question with FB442 bracket jtjordan07 Electrical 5 07-04-2014 12:04 PM
Pex Install Question -M- Plumbing 6 06-25-2014 08:22 AM
question on correct install of Belgium block Sampson Concrete, Stone & Masonry 0 06-13-2014 03:44 PM
1" hexagon tile mat install question gwilkrrs Tiling, ceramics, marble 0 11-09-2013 06:01 AM
