Is It Wrong To Leave Pressure Gauges Permanently Under Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2016, 12:37 PM   #1
Rewards Points: 327
Is it wrong to leave pressure gauges permanently under pressure
My house has an older pressure reducing valve that still seems to work okay. I was reading the old install manual for it, and it states that the pressure gauges should not remain under pressure, but should be isolated by a valve. Mine do not have isolating valves.
Is it wrong to leave the gauge under normal pressure? It seems I've seen lots of gauges besides mine installed without a separate valve.
And even if there were a valve, when you shut it off, you'd just be sealing it at that same pressure. To relieve it, you'd have to loosen the gauge itself.
Any thoughts?
dave11 is offline   Reply With Quote
Old 08-03-2016, 03:33 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,734
Re: Is it wrong to leave pressure gauges permanently under pressure
I guess it would depend on the manufacturer of the gauge, but domestic water systems have a gauge that is constantly under varying amounts of pressure. So do air compressors.
lenaitch is offline   Reply With Quote
Old 08-03-2016, 09:17 PM   #3
Rewards Points: 1,854
The gauges will eventually quit reading due to build up on material leading to the diaphragm of the gauge. In other words they get stuck. Gauges are cheap and easily unscrewed and replaced as needed.
Roof safety anchors...leave them in permanently? sockersfc2002 Roofing/Siding 6 11-25-2014 09:04 AM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
is it a bad idea to leave an air compressor under pressure ? amakarevic Building & Construction 4 06-13-2008 02:35 PM
