Worried About Crazy Water Pressure In Hose - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree9Likes
Old 09-15-2017, 07:52 PM   #16
Plumber
TheEplumber's Avatar
Re: Worried about crazy water pressure in hose
Originally Posted by highdesert67 View Post
OK so I bought a 100 PSI water meter and I connected it to the bib outside. Outside the needle shot past 100, and completely pegged at the top. So I don't know what it is, but I know that it is above 100 PSI. I then connected it to the washer valve inside end it also shot past 100 PSI and pegged at the top of the meter. So what are my options at this point? Should I call the water company first? Also how urgent of a situation is this?
Yes, talk to them. They are probably not liable for extreme pressure though. But you can quiz them on the best way they would like to see it resolved. By this I mean installing a PRV at the house side of the meter, or inside your house near your shut off.
You are under UPC code and the maximum delivery pressure allowed is 80 psi.
Again, that does not apply to water dept. delivery- just the house side.
For what it's worth- 60 psi is considered normal.
You can see what extreme pressure can do to a main line. Consider what it's doing in a toilet tank fill valve or faucet....
Old 09-15-2017, 08:00 PM   #17
retired framer
Rewards Points: 15,354
Here is the valve
MTN REMODEL LLC likes this.
Old 09-16-2017, 05:14 AM   #18
retired painter
Rewards Points: 1,976
Look where the water enters the house, there should be a pressure reducer valve. They are adjustable although it's likely it's gone bad. My son bought a house that had been replumbed a year before he bought it. He had it about a year when a pipe under the house blew apart. That is when we found there was no PVR installed so I installed one, 9 yrs later still no pressure issues.
mark sr is online now   Reply With Quote
Weird water pressure issue in house... tenants moving in today, any ideas? (w/pics) tireshark Plumbing 9 08-19-2014 03:54 PM
Low Hot water pressure after replacing laundry hose connection jp_jacobson Plumbing 4 05-03-2011 07:30 AM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 12:04 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
