Wood Shower Floor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-29-2016, 08:51 PM   #1
Rewards Points: 3,164
Wood shower floor?
So, I'm wanting to do something a bit different. Maybe more than a bit different...
I've got a very odd size shower here at the beach and thought I would install a, raised just above the tile, slat wood floor. I have the same thong in the outdoor shower, although that just drains into a grave filled pit.
Teak, Cedar, Mahogany?
Thoughts and opinions?
ktkelly is online now   Reply With Quote
Old 02-29-2016, 09:01 PM   #2
Rewards Points: 270
Cool idea. I'd go with teak, but I'm guessing you'll have a lot of slimy mold clinging to this on an indoor shower.
b-boy is offline   Reply With Quote
Old 02-29-2016, 09:59 PM   #3
JUSTA MEMBER
Rewards Points: 3,134
Look at a wood called e-pay, ( probably spelled wrong), it is a brazilian hard wood that is very water and mold/ rot resistant, it ain't cheap, but quite attractive.
A good idea, I approve.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Bondo (03-01-2016)
Old 02-29-2016, 10:56 PM   #4
Rewards Points: 1,414
Concur on the teak. Not sure about the mold--you might try putting the fan in there on a timer if it seems to be a problem.
Tom738 is offline   Reply With Quote
Old 03-01-2016, 07:57 AM   #5
Rewards Points: 144
ED
ipe. Just so we know.Nice wood and used on many decks.
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
Bondo (03-01-2016), de-nagorg (03-01-2016)
Old 03-01-2016, 08:05 AM   #6
WhatRnsdownhill's Avatar
Rewards Points: 2,220
will the wood be removable?
WhatRnsdownhill is offline   Reply With Quote
Old 03-01-2016, 09:58 AM   #7
Yes,
I made the floor for the outdoor shower in the same manner using 1x1's to build a base frame, then 1x2's for the surface. This just lays on top of the base, which in this case will be the actual tile floor.
I really don't think it'll get any mold, as it will be able to dry out both top and bottom. But we'll see. Worst case, I have to lift it out, take it outside, pressure wash it and let it dry before laying it back in the shower.
The idea is that this will lend more to the "tropical" feel of the beach house bathroom. It will be just another tie in to the theme of the rest of the place (palms, pelicans, nautical, etc, etc.).
What the hell. It doesn't work out, I pull it out and the tile floor is still there.
Could I do it, I'd have a shower large enough for a palm tree and a hammock....
The Following User Says Thank You to ktkelly For This Useful Post:
Old 03-01-2016, 10:37 AM   #8
JUSTA MEMBER
Don't forget the cool breezes, open views , and Pina Coladas.
Then there's the giant Banana Spiders, Iguanas, and assorted creepy crawlies.
ED
Old 03-01-2016, 10:50 AM   #9
Rewards Points: 5,452
If Western Red Cedar and/or Mahogany is available locally it would be a coin toss for me but I do favor Mahogany to work with when sawing, routing edges etc.
For small projects as in your instance where weather / moisture is related and I want a natural appearance rather than an opaque paint, I usually go for my old favorite, a coating of hot paraffin applied to all surfaces pre assembled. It may need a touch up in 4-5 years depending on exposure and use.
In lieu of a torch several other heat sources such as heat lamps, paint strippers etc. including the sun will work with similar results. I like the torch to judge the heat with because an occasional flame lets me know I have heat at its maximum.
Old 03-01-2016, 10:53 AM   #10
ED
Cold Corona's for me, and there better not be any critters in my bathroom, other than me of course...
I see you're in Wyoming. Wife and I will be touring there in September,
Grand Tetons, Yellowstone, over to Big Horn, and then points south. Really looking forward to it...
Old 03-01-2016, 11:09 AM   #11
Yes,
thats why I asked, if you can let it sit in the sun for a few hours, and then give it a coat of oil, that will work good..
Old 03-01-2016, 12:05 PM   #12
JUSTA MEMBER
Wyoming has some beautiful places to visit, You named some of them.
And many drab ugly spots too, but they just don't advertise it.
There is a place just east of me called HELLS HALF ACRE, that was used as a backdrop for that movie STARSHIP TROOPERS, I guess that beauty is in the eye of the beholder, as I think that it is ugly.
ED
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Installing 9mm bamboo over 9mm wood floor and concrete hellobritt Flooring 4 08-30-2011 09:35 PM
Adequate floor support for new shower? daveofnj Kitchen & Bath Remodeling 5 05-09-2010 02:27 PM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 06:29 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
