Winterizing Fire Sprinkler Systems - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2016, 08:49 PM   #1
Rewards Points: 208
Winterizing fire sprinkler systems
Last winter I was in Florida when we were hit at home by snowzilla. There were reports of extended power outages nearby so I sweated
it out by calling neighbors and in the middle of the nite by calling my answering machine to see if the power was out for any extended time.
I was concerned with the damage that could be done by a frozen fire sprinkler system. I assume it will freeze and burst, is that correct?
Any idea how long it would take? In my previous house, I would just turn the HWH and water supply off before I left. I think I recall that
my house insurance requires me to keep the water supply on for the sprinkler system. Can anyone provide advise as to what I should do.
We pretty much spend 2-4 weeks down south during every jan/feb.
thanks
partner is offline   Reply With Quote
Old 08-27-2016, 09:06 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: Winterizing fire sprinkler systems
Where in Florida are you located? Not many parts of Fl stay cold enough long enough to freeze pipes.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 08-27-2016, 09:17 PM   #3
Rewards Points: 208
I was in Florida on Vacation. I'm a snow bird. It freezes pretty good in northern MD.
Old 08-28-2016, 09:09 AM   #4
JUSTA MEMBER
Rewards Points: 3,172
A simple solution is to install a stand-by power generator.
It keeps the power on to run the heat for your MD. home, when and if the Grid goes down.
ED
de-nagorg is offline   Reply With Quote
Old 08-28-2016, 09:15 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
ED
I wouldn't call that simple.
You can have antifreeze installed in the system.
Old 08-28-2016, 10:45 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 170
Or convert to a dry system
Old 08-28-2016, 10:49 AM   #7
GrayHair's Avatar
Rewards Points: 1,436
The residential sprinkler systems I saw used a special plastic tubing in place of pipe and I would be averse to putting any type of antifreeze in it. Probably best to consult the company that installed the system. The thing I would never want to fool with an insurance policy.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Stripping off old paint bwspot Painting 71 11-28-2013 12:43 AM
Fire sprinkler Miami Fl dreamerkhair Plumbing 5 05-24-2013 10:51 PM
Distance from fire sprinkler head kramtarts Building & Construction 1 03-16-2012 01:00 PM
Light Fire Restoration / Odor Concerns gkotlin Painting 9 01-19-2012 06:40 AM
Electrical Fire seansy59 Electrical 1 10-24-2011 05:57 PM
