Winterize Underground Sprinkler Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2016, 05:41 PM   #1
Rewards Points: 6
https://www.facebook.com/photo.php?f...8&l=0d70420c09
https://www.facebook.com/photo.php?f...8&l=5c739bf2f1
https://www.facebook.com/photo.php?f...8&l=1a6511d524
https://www.facebook.com/photo.php?f...8&l=797ea34df5
Hello,
I am planning on winterizing my Underground Sprinklers and am having trouble trying to find the place to hook up my compressor. I have taken a good look for all potential sites around my home and found the places (pictures above). I have a 4 zone system as seen in pic 3, there is no apparent hook up within the underground box. The vertical PVC pipes are right next to the box and one of the pipes appears to be simply to house a wire and is not connected to the water system. The second picture is where I would assume the RP or PVB systems with valves and hookup locations but all I can find is this capped pipe. The in home main line has no other valves or hook up locations and assume that the one ball valve pointing up is the shut off but can't know for sure.
Please help,
Dan
danb_2000 is offline   Reply With Quote
Old 09-27-2016, 08:24 PM   #2
Rewards Points: 6,340
Re: Winterize Underground Sprinkler Problems
Without a schematic / diagram you're pretty much left with a process of elimination.
Start by closing the valve at the meter and relieving pressure then momentarily opening that valve up after a suspect irrigation pipe is opened to check for flow. Then close the ball valve mentioned and repeat. If no flow at that time the ball valve shuts irrigation supply off.
Old 09-27-2016, 09:45 PM   #3
Rewards Points: 278
You can remove the cap on the pipe coming out of the house after shutting off the water. Connect your air line to that pipe and cycle each zone until the water is blown out. I hope you have a big compressor.
Dan
djlandkpl is offline   Reply With Quote
Sprinkler System Winterize? psychoguy42 Landscaping & Lawn Care 4 10-14-2013 04:02 PM
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
locating underground sprinkler lines denemante Landscaping & Lawn Care 9 02-14-2012 09:24 AM
underground electical lines BlueBSH Electrical 11 02-10-2012 03:52 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
