Winter Time - How To Prevent Frozen Pipes To Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
Old 01-02-2018, 01:14 PM   #16
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Winter time - how to prevent frozen pipes to tankless water heater
Originally Posted by HouseBuilder328 View Post
Temperature in central NC was 12 degrees last night, and 16 degrees the previous 2 nights. Left the kitchen faucet dripping on the hot water side - obviously that's too low of a flow to activate the gas tankless heater. No frozen pipes like last time.
Running a large quartz radiant space heater in the garage probably costs more money. This only happens here once a year for a few days
or until you open garage doors during freezing weather
garages & water pipes don't play well together
never have - never will (even in sweet Caroline)
good news is your unit can protect itself on bypass
Peace
DR P is offline   Reply With Quote
Old 01-02-2018, 01:27 PM   #17
ZTMAN's Avatar
Rewards Points: 628
When I bought my first house 35 years ago, no basement, the prior owner put the water softener in the garage. Not a good idea in PA.
After it froze, I built a little enclosure with ridged insulation, and put a 100w light inside the enclosure. Not the best solution, but it worked during the PA winters.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Adding Tankless Water Heater with Hot Water Tank cterrier Green Home Improvement 10 04-14-2017 09:33 PM
Tankless Water Heater & Pex Questions jdm001 Plumbing 7 12-18-2015 10:01 AM
Tankless water heater reedle87 HVAC 3 03-16-2012 01:23 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 12:46 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
