Will The Drain / P Trap System Work - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2016, 02:03 PM   #1
Will the drain / p trap system work
I am concerned about slow draining especially. Are there any other concerns I should have? This will be installed in very tight place w no access underneath.
Will the drain / p trap system work-20160413_141215_1460574139884.jpg
Pirojc is offline   Reply With Quote
Old 04-13-2016, 03:11 PM   #2
Rewards Points: 3,208
Re: Will the drain / p trap system work
If there is not going to be any access, the trap needs to be glued with no compression fittings. What you are showing has a compression nut.
If the line is draining slow, a new trap wont make any difference. You have a partial blockage somewhere or a venting problem. Was line snaked?
Pleae wait, the plumbers will be along shortly. Thanks.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
SHEPLMBR (04-14-2016)
Old 04-13-2016, 04:51 PM   #3
Rewards Points: 18,768
Impossible to tell from this picture what where even looking at.
What's the drain for?
Old 04-13-2016, 04:56 PM   #4
Thanks jmon! This is a rehab of my bathroom. Everything is new. If I may, let me explain a bit more. The elevation of the 1.5 " pipe before /after p trap is only about 3/4" difference. Is that a problem?
Old 04-14-2016, 11:12 AM   #5
Rewards Points: 1,602
I'm assuming you're not planning to put it in that orientation. Aka, not sideways.
mikegp is offline   Reply With Quote
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 09:13 PM
How to replace furnace drain trap burnzyd HVAC 2 04-07-2012 09:26 AM
Please Help Me With This French Drain System! coderguy Landscaping & Lawn Care 56 03-28-2012 07:35 AM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
