Will Circulator Pump Stop Flow If Leave In Zone? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2016, 08:00 AM   #1
Rewards Points: 4
Will circulator pump stop flow if leave in zone?
* leak in zone*
if the heat and circulator are not running, and the zone copper pipe is punctured... Will there be an endless leak of water or will the water in the zone just drain out? Or will the zone keep filling from the flow as long as the flown value is open?
Nyliguy is offline   Reply With Quote
Old 06-01-2016, 09:49 AM   #2
Rewards Points: 3,294
Re: Will circulator pump stop flow if leave in zone?
Originally Posted by Nyliguy View Post
* leak in zone*
The circulator is not a perfect seal when stopped. So water will continue to leak out of a break in the pipe loop further on unless the boiler does not have autofill from a water line.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
flow control valves jmon HVAC 9 12-12-2012 10:53 AM
help with 2 zone electic heat pump ctkulig HVAC 1 12-07-2009 06:19 AM
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 04:54 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 12:02 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
