Why Is There A Manhole Above The Sewer Line? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By MTN REMODEL LLC
Old 05-06-2017, 06:33 PM   #1
Why is there a manhole above the sewer line?
I was digging to the house main sewer line where there's root issues and found a manhole size object above the sewer line. Not sure if it's a manhole, the top doesn't appear to be removable. The inside is empty about 2 feet down. House was built in 1920.
Any idea what it is?
Problem posting photo.
CenterPunch is offline   Reply With Quote
Old 05-06-2017, 06:42 PM   #2
Property Mgt/Maint
Rewards Points: 8,202
Re: Why is there a manhole above the sewer line?
Sounds like a drywell. Or is a septic tank below? Sometimes folks will put a riser above a cleanout with a cover over it. Less digging when it's time to pump.
Post a few more times and the site will let you post your pics
Yodaman is offline   Reply With Quote
Old 05-06-2017, 07:02 PM   #3
There's no cleanout that I can see. I'll keep digging to see how far down it goes.
Hard to say if the sewer was there when the house was built, I can check with the city on Monday.
Old 05-06-2017, 07:13 PM   #4
Old 05-06-2017, 07:21 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,870
Looks like somebody buried a big can down there.... maybe it's Jimmy Hoffa....?
MTN REMODEL LLC is online now   Reply With Quote
Old 05-06-2017, 07:31 PM   #6
Rewards Points: 1,942
Any bones in there? Might be somebody's grave.
Old 05-06-2017, 07:34 PM   #7
Great minds think alike.....
Bondo and Nik333 like this.
Old 05-15-2017, 07:34 PM   #8
Old 05-15-2017, 07:34 PM   #9
I think you got it right Yodaman, looks like a graywater drain and should be safe to remove. I dug down to the sewer line and here's a photo of the 55 gallon drum. The pipe connected to the drum is pointed to the garage. Garage had plumbing installed years ago, probably replacing the old graywater drain.
It's in the way of the sewer line repair and will be removed.
Old 05-15-2017, 08:16 PM   #10
Property Mgt/Maint
Wow, lines running in all directions. Must of been fun trying to dig out.
I have a similar set up that handles the runoff from the tool shed.
Old 05-15-2017, 10:53 PM   #11
Rewards Points: 68
I bet there is a old Timex watch in the barrel..."takes licking and keeps on ticking"
man00 is offline   Reply With Quote
School me on backwater valves (for sewer line) MrBryan Plumbing 9 09-15-2014 02:00 PM
Need help sewer line help... jaeevans Plumbing 4 09-02-2014 08:02 PM
finding a sewer line av-geek Plumbing 16 01-19-2012 06:56 PM
Help!!! Roto-rooter cable is now stuck in sewer line and won't come out!!! YerDugliness Plumbing 21 01-28-2010 03:04 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
