Why Sump Pump Tripped Dedicated Gfci - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 2 Post By hkstroud
  • 1 Post By Ghostmaker
  • 1 Post By XSleeper
Old 10-16-2017, 07:53 PM   #1
Rewards Points: 62
why sump pump tripped dedicated gfci
I recently had a reputable plumbing company install the pro series ps-c33, the other day the dedicated outlet it was plugged into had the gfci trip, stopping the unit from getting ac power, which I got alerted to of course. I reset the gfci and all is well, but why would this unit have tripped the gfci, as its well under the circuit capacity?
lightadjust2000 is offline   Reply With Quote
Old 10-16-2017, 09:48 PM   #2
Rewards Points: 898
Re: why sump pump tripped dedicated gfci
Could be a lot of different reasons.
BIG Johnson is offline   Reply With Quote
Old 10-17-2017, 08:28 AM   #3
hkstroud's Avatar
Rewards Points: 6,694
I would never use a GFI outlet for a sump pump, a refrigerator or a freezer.
Never.
I don't care what the NEC says.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 10-17-2017, 02:10 PM   #4
Rewards Points: 1,932
I actually had to replace my Ground Fault breaker because it was constantly tripping. Once replaced with new no tripping.
stadry likes this.
Old 10-21-2017, 03:56 PM   #5
Rewards Points: 3,556
if you'd had a pro wtrproofer do the work, they'd have probably used a zoeller m-53 1/3rd hp that has a startup rqmnt of 9.7amps & run of 4.3,,, plumbers aren't the correct trade for this work impo,,, liberty'd be my 2nd choice
Old 10-21-2017, 05:50 PM   #6
Rewards Points: 1,739
Just another reason why a battery powered backup sump (and alarm) is a good idea... it happens. IMO, it's also a good idea to have that GFCI placed somewhere it can be reset without stepping in water... and if that's not possible, kill power to the circuit, reset the GFCI, then restore power to the circuit.
jeffmattero76 likes this.
XSleeper is offline   Reply With Quote
Old 10-23-2017, 06:09 AM   #7
if on city water, better idea is wtr-power'd backup,,, battery b/u's just don't have the ***** in hvy leaking situations
Old 10-23-2017, 06:46 AM   #8
Naildriver
chandler48's Avatar
Rewards Points: 3,532
GFCI's don't trip on overload. They trip on the potential difference between the hot and neutral, so in essence, you had a ground fault, not an overload. Likewise, if it is a dedicated circuit and you experience GFCI tripping, it could be a leak in the motor where the wiring enters or along the cord. A normally open switched alarm would be mandatory, IMO to alert you to a failure.
Edit: was a GFCI receptacle installed or a GFCI breaker??
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Sump Pump Running Constantly - Never Ending Water! seldom Plumbing 7 12-08-2015 07:59 AM
Backup sump pump & check valve issues Richo Plumbing 8 04-30-2015 10:42 PM
On my way to create the ultimate Sump Pump system... need your input :) Discovery Plumbing 5 06-10-2012 07:37 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 06:14 PM
