Why, Oh Why - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2015, 01:51 PM   #1
raylo32's Avatar
Rewards Points: 1,694
why, oh why
I just replaced a broken toilet flush handle/rod and somehow I recalled that the nylon nut is left hand threaded. But since the handle has a square insert that fits into the toilet tank operating the handle should not put any torque that could loosen that nut so why on earth is this thing left hand thread? Me and guys are just curious if there is a long lost reason for this?
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 10-15-2015, 02:01 PM   #2
Sippin' Tea
Sdyess's Avatar
Rewards Points: 110
I'm not sure but isn't the flush mainly on the left side?
Sdyess is offline   Reply With Quote
Old 10-15-2015, 05:46 PM   #3
Rewards Points: 1,932
Because those who like to tighten things backwards need a job to.
The Following User Says Thank You to Ghostmaker For This Useful Post:
gassyplumber (10-15-2015)
Old 10-15-2015, 07:51 PM   #4
Rewards Points: 3,416
In case the handle assembly is installed in a different brand of toilet tank with a round instead of square corner mounting hole. (With filing the outside of the square insert to be round if the hole was too small.)
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
AllanJ is online now   Reply With Quote
