Why Not Use A Hydronic Expansion Tank For Potable Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2019, 12:17 PM   #1
Rewards Points: 219
why not use a hydronic expansion tank for potable water
The small expansion tank for our well leaks on the outside and the air side had rusty water, it was 9 years old. It says on it for hydronic heat systems. It says in small print, not for domestic water systems
I happen to have a new one, also for a hydronic heat system, says on it, not for potable water.
Why not use a hydronic expansion tank for potable water?
bkvanbek is offline   Reply With Quote
Old 08-08-2019, 12:36 PM   #2
retired framer
Rewards Points: 962
Re: why not use a hydronic expansion tank for potable water
It may have all the right stuff but it would add to their cost to have it certified for food use and would not likely add to sales.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
bkvanbek (08-08-2019)
Old 08-08-2019, 01:33 PM   #3
Oso954's Avatar
Rewards Points: 80
Hydronic heater tanks often have no lining. If one is used, they donít pay extra for a potable water rated liner material. They donít expect people to be drinking from the heating system.
The water system needs a potable water rated tank.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 08-08-2019, 05:28 PM   #4
Rewards Points: 80
Not only is the certification expensive, hydronic tanks can be all steel. A hydronic loop is an oxygen starved environment. Potable water systems are open and oxygen rich. So either the tank needs a liner, or be made out of other materials.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
Old 08-08-2019, 05:28 PM   #5
HenryMac's Avatar
Rewards Points: 1,024
Potable water pressure tanks aren't that expensive, why risk your health?
HenryMac is offline   Reply With Quote
Old 08-09-2019, 05:23 PM   #6
Rewards Points: 2,118
Cancer isn't fun.
Old 08-09-2019, 08:54 PM   #7
Rewards Points: 219
Originally Posted by Ghostmaker View Post
Cancer isn't fun.
Like from steel pipes, steel well casing and such?
Old 08-09-2019, 10:08 PM   #8
Rewards Points: 80
It wouldn't be untreated, raw iron, otherwise It wouldn't last very long.
Besides, everything is recognized as a cause of cancer in California. I don't live there, so I'm safe?
Cheers!
Old 08-10-2019, 08:49 AM   #9
Rewards Points: 219
Cheers!
Of course well casing would you rather have your water through galvanized? I am in MN so I am safe too.
