Why Is My Toilet's Fill Valve Spraying Sideways? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2017, 01:01 PM   #1
Rewards Points: 128
Why is my toilet's fill valve spraying sideways?
Doesn't happen every flush. After I took the below photo, I lifted and dropped the "floaty" thing (ballcock?) and the fill valve then operated normally, without spraying all over the place.
Is there some adjustment I can do or do I need a new valve?
MattBK is offline   Reply With Quote
Old 12-13-2017, 03:27 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Re: Why is my toilet's fill valve spraying sideways?
Normally I would tell you to replace the flush valve but that is a 1 piece Kohler toilet and that flush valve is expensive. Try removing the blue cap on the top (shut water off first) and see if the O-ring is out of position or worn.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
MattBK (12-14-2017)
Old 12-13-2017, 10:18 PM   #3
JUSTA MEMBER
Rewards Points: 3,780
And Kohler should have rebuild kits for it, complete with directions on how. new O ring. and spring .
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
MattBK (12-14-2017)
Old 12-14-2017, 11:58 AM   #4
hkstroud's Avatar
Rewards Points: 6,694
http://helptopics.us.kohler.com/link...et-Fill-Valves
https://www.supplyhouse.com/Fluidmas...yAAEgJFAvD_BwE
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
MattBK (12-14-2017)
Leaky Shower gypsy57 Plumbing 17 08-24-2016 10:37 AM
Help!!! Replace fill valve in bathroom toilet problem tman1978 Plumbing 1 04-18-2016 11:28 PM
Do I need a new fill valve? mudeprived Plumbing 6 11-09-2015 01:57 AM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
fill valve, boiler related pmacedo HVAC 15 12-31-2007 11:45 AM
