Why Are Inlet Hoses Strong And Durable But Drain Hoses Are Thin And Flimsy? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2015, 10:13 AM   #1
Rewards Points: 16
Why are inlet hoses strong and durable but drain hoses are thin and flimsy?
I'm in the process of installing a dishwasher and I want to choose the best hoses to minimize any chance of leaking/flooding. It seems a little odd you can buy a durable stainless steel inlet hose but most drain hoses are thin pvc?
Are leaks more likely to come from one hose more than the other? Or about the same?
wesleysnipes is offline   Reply With Quote
Old 06-24-2015, 10:23 AM   #2
Rewards Points: 6,286
It has to do with the pressure differential -supply vs drain.
Don't let the expensive stainless impress you too much. I suspect if you cut it you would find a plastic tubing inside.
Old 06-24-2015, 11:52 AM   #3
Special User
Rewards Points: 1,230
The stainless just protects a (usually rubber) hose from external cuts and helps prevent rupture from pressure in a weak spot. Not much pressure on a drain hose.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 06-24-2015, 08:26 PM   #4
Rewards Points: 18,952
By far one of the biggest insurance claims is from water damage caused from old rubber and plastic hoses.
Always go with stainless steel braided hoses on a washing machine, dishwasher, sink supply's.
Old 06-24-2015, 08:37 PM   #5
Rewards Points: 6,652
Waste of money. Those hoses can still burst like any other type of hose. All the Stainless braid does for them. Is make them look all nice and pretty.
