Why Doesn't My Toilet Flapper Drop Down After Flush? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2015, 07:17 PM   #1
Rewards Points: 91
Why doesn't my toilet flapper drop down after flush?
My flapper flush chain rotted off. I bought a new chain and attached it. When I flush the flapper comes up draining the tank. Heres where the problem comes in. The flapper attaches at the overflow tube but on the opposite side of the fill tube...opposite the flapper, there is a cup attached to the flapper assembly. The cup fills with water when the tank is full and when you flush, the cup should empty through the little drain hole in it. It seems to be draining but the flapper still will not drop. Can I simply cut this cup off so it is not counter balancing the flapper assembly? Whats the cup for? Am I making sense? I am including a picture of the type of flapper I have.
sofasurfer is offline   Reply With Quote
Old 12-20-2015, 07:42 PM   #2
Rewards Points: 3,208
Don't quite understand the cup. Is it something like this: You may have it installed wrong.
http://www.fluidmaster.com/downloada...sample_id/272/
http://www.fluidmaster.com/our-produ...flapper-1.html
jmon is online now   Reply With Quote
Old 12-21-2015, 08:50 AM   #3
Rewards Points: 3,270
THe cup is meant to keep the flapper from dropping too quickly.
Are there other obstructions in the toilet tank that the cup hits?
What does the instructions for the flapper say about the cup?
Is there a provision for putting added weight (perhaps a few pennies) on the flapper side to adjust the flapper drop timing?
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
toilet flush and AAV benleef Plumbing 12 01-21-2013 09:23 PM
Toilet flapper closes too soon dfiddler General DIY Discussions 4 06-11-2012 10:10 AM
Gerber Pressure Toilet does flush all the way jimrens Plumbing 0 05-10-2011 09:10 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
