Why Do Frozen Pipes Burst? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
Old 10-23-2016, 06:00 AM   #16
Rewards Points: 2,820
Re: Why do frozen pipes burst?
Good discussion and I want to add one of the more important solutions to freezing pipes. Where wrapping them in insulation helps it will often not be enough. Where possible, insulation should be located between the pipe and the cold area and leave the pipe exposed to the source of heat, the warmth of the house.
Bud
Bud9051 is online now   Reply With Quote
Old 10-23-2016, 06:43 AM   #17
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,706
Bud
Good point. My inspector called this one out.
The first pic is what the "pros" did.
Second pic is my repair.
Why do frozen pipes burst?-img_9732.jpg   Why do frozen pipes burst?-img_9755.jpg
123pugsy is offline   Reply With Quote
Old 10-23-2016, 07:09 AM   #18
Property Mgt/Maint
Rewards Points: 8,202
Pugs, btw, doing a fantastic job with the house!
Bringing the supply lines up thru the floor and away from a outside wall would be another option. It's not always practical, but I try to stay out of out side walls altogether.
Yodaman is offline   Reply With Quote
Old 10-23-2016, 08:35 AM   #19
123pugsy's Avatar
Thanks.
In my case above , you can see a false wall that the pipes and duct are in with a full 6" Roxul behind.
I agree about keeping supply pipes out of the outside walls. Kitchen sink is on an outside wall with supply pipes thru the floor.
Yodaman likes this.
Tags
burst , frozen , pipe
Frozen Pipes from well to house Moon Mountain Plumbing 13 08-03-2016 08:13 PM
Help! I think my pipes are frozen! kevind Plumbing 4 02-02-2011 05:36 PM
Frozen pipes shaikh Plumbing 2 01-08-2010 05:50 AM
installing electric heat garage - frozen pipes? mothgraphics Electrical 10 12-20-2009 12:29 PM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
