Why Do Frozen Pipes Burst? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
Old 10-22-2016, 01:20 PM   #1
Rewards Points: 12
Why do frozen pipes burst?
Is it because
1) Water expands when it turns to ice. When water in a pipe turns to ice it expands and burst the pipe.
2) when water turns to ice it compresses water downstream. This pressure in the compressed water eventually bursts the pipe, not the expanding ice.
Thanks for any help.
karunnt is offline   Reply With Quote
The Following User Says Thank You to karunnt For This Useful Post:
Nik333 (10-22-2016)
Old 10-22-2016, 01:31 PM   #2
Rewards Points: 1,528
Re: Why do frozen pipes burst?
Number 2..
ryansdiydad is offline   Reply With Quote
Old 10-22-2016, 01:44 PM   #3
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
Number 1
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
rjniles (10-22-2016)
Old 10-22-2016, 02:14 PM   #4
Rewards Points: 12
Originally Posted by 123pugsy View Post
Number 1
The why doesn't a glass of water crack when you put it in the freezer?
Old 10-22-2016, 02:38 PM   #5
Rewards Points: 18,796
Because it has room to expand at the top.
There is no room for expansion in a closed water pipe.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
123pugsy (10-22-2016), Power- (10-22-2016), rjniles (10-22-2016)
Old 10-22-2016, 03:00 PM   #6
Civil Engineer
Rewards Points: 5,246
You may want to look at the following website, which provides a nice explanation as to why the high water pressure created by the expanding ice breaks the pipe, not the ice itself. http://www.livescience.com/43408-why...pes-burst.html
Old 10-22-2016, 03:39 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 31,670
Both 1 and 2 are the same thing. When water freezes it expands. Expanding frozen water bursts pipe or expanding frozen water compresses unfrozen water to burst pipe. Both are the result of freezing water expanding.
If you look at frozen water in a glass you will see a mount on the surface. That is the frozen water expanding. It has room to come up. If the glass was a jar with a lid it could burst if the jar was full enough and the lid tight enough.
Old 10-22-2016, 03:45 PM   #8
Rewards Points: 2,210
I'm not even going to read the link as increased water pressure is NOT the cause of a pipe bursting when the water inside freezes.
A. Every burst pipe I have repaired has burst right where it froze.
B. The expansion resulting from the water in one area of the pipe freezing is minute in relation to the volume of water in the system.
C. Ultimately, the pressure relief on the hot water side is still part of the system and it would release long before a pipe would burst.
Pugsy has it right, #1
Bud
123pugsy, supers05 and Power- like this.
Bud9051 is online now   Reply With Quote
Old 10-22-2016, 05:03 PM   #9
Civil Engineer
Bud, you may want to read that article, I know you are convinced that the expansion of the freezing water causes the pipe to burst, but the article makes a persuasive case that the pressurized water actually bursts the pipe in most cases. Article includes photos. Consider that in a pipe, as the water freezes, the ice can expand into the part of the pipe that is still liquid. On the inlet side from the street, the expanding ice can push the water out. On the outlet side in the house, the water may not have anywhere to move, for example a pipe which leads to a water faucet.
In the case where the water is trapped, the pressure will increase rapidly, since the bulk modulus of water is very high (about 320,000 psi), so a small percentage increase in volume leads to a large increase in pressure. Ice also has a high bulk modulus, so if the ice cannot expand, for example water completely fills a sealed container, then the container is frozen, the ice will crack the container.So if you freeze a full container in the freezer, you will likely crack the container.
Old 10-22-2016, 05:32 PM   #10
I did read the article and do understand what he is saying, but it doesn't match what I've seen in the real world. Pipes where the water has been left running can still freeze and burst where the ice is. Frozen pipes that are 20 feet away from any closed faucets still freeze and again burst where the ice forms.
I'm not a plumber so repairing burst pipes has only be the occasional task, but I will keep his explanation in mind if the future presents me with any more burst pipes. Doubtful given my age.
I agree it is a possibility.
Bud
PS I knew you were going to make me read the article .
Power- likes this.
Old 10-22-2016, 07:12 PM   #11
Rewards Points: 12
It can expand upstream into the water supply system. That is less than 100psi.
I asked this question because I read both causes on genuine plumber's websites and something seemed wrong. I think the solution is #2 but I may be wrong.
Old 10-22-2016, 07:52 PM   #12
Rewards Points: 3,290
In a water filled closed space, including a section of pipe between two plugs of ice, the pressure everywhere within that space is the same. As additional water freezes within the closed space in question, the pressure rises more.
For the pipe where disjoint portions of the contents froze, at first the plugs of ice will crack and/or push lengthwise depending on the pressure of the water on each side of the plug but eventually the plug is too large to break up or move. Then the pipe breaks at its weakest point.
If an open glass container of water is allowed to freeze, we cannot rule out breakage of the glass if the layer of ice across the top had gotten quite thick.
Simply insulating a length of pipe passing through an unheated area might not protect it from freezing. Usually the pipe relies on itself conducting heat from the interior of the building and hopefully the far end, for example the hose bibb, is the coldest and freezes first with freezing gradually progressing inward so there is never a pocket of water with plugs of ice on both sides. Plastic pipe does not conduct heat well and would be more likely to burst in this situation.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 10-22-2016, 09:46 PM   #13
Rewards Points: 12
Originally Posted by Bud9051 View Post
... Pipes where the water has been left running can still freeze and burst where the ice is. Frozen pipes that are 20 feet away from any closed faucets still freeze and again burst where the ice forms.
This may explain your experience why pipes burst where ice forms.
http://dsplumbing.ca/plumbing-repair...s-information/
Ice supposedly forms from the walls of the pipe towards the center so it may leave localized pockets of liquid along the pipe that are compressed.
I am not an expert at all.
Old 10-23-2016, 05:39 AM   #14
123pugsy's Avatar
If ice formed on the outside walls first, the rupture in my experiment below would be somewhere in the center.
I believe both theories have merit and it's probably a mixed bag of which actually causes the rupture depending on the location of freezing.
Why do frozen pipes burst?-img_1165.jpg   Why do frozen pipes burst?-img_1167.jpg
Old 10-23-2016, 05:59 AM   #15
kwikfishron's Avatar
Rewards Points: 336
All the frozen pipe burst Iíve dealt with have showed up during the thawing cycle. As the ice thaws the water now can reach the break and thereís your leak.
If #2 was true, then pipes would be bursting and leaking during the freeze event vs when things are thawing. I wonít say it canít happen but Iíve never seen it.
123pugsy likes this.
kwikfishron is online now   Reply With Quote
Tags
burst , frozen , pipe
Frozen Pipes from well to house Moon Mountain Plumbing 13 08-03-2016 08:13 PM
Help! I think my pipes are frozen! kevind Plumbing 4 02-02-2011 05:36 PM
Frozen pipes shaikh Plumbing 2 01-08-2010 05:50 AM
installing electric heat garage - frozen pipes? mothgraphics Electrical 10 12-20-2009 12:29 PM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
