Whole House Water Filter - Flow Rate - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2016, 09:36 PM   #1
Rewards Points: 126
Whole house water filter - flow rate
I am looking to install a whole house water filters (simple inexpensive cartridge type, not a big complex system), and they all advertise a flow rate, usually 5 gpm, some higher. What does this refer to? The maximum flow possible through the filter? Or just the maximum flow recommended for the most filtering, but flow can be higher? I know sometimes I will exceed 5 gpm.
Thanks!
garrett1812 is offline   Reply With Quote
Old 02-03-2016, 06:43 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
the flow rate will change depending on what type of filter element you put in, and as it gets dirty the flow rate will diminish..so get a big enough filter to give you what you need...
WhatRnsdownhill is offline   Reply With Quote
Old 02-03-2016, 08:40 AM   #3
Rewards Points: 582
aqua pure model ap 810 whole house 20 gpm
Water softener and whole house filter Verbalkint99 Plumbing 1 08-06-2015 10:58 AM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Whole house water filter location Soloed Plumbing 2 02-04-2008 07:32 AM
