Whole House Low Water Pressure/flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2017, 06:16 PM   #16
Usually Confused
lenaitch's Avatar
Rewards Points: 2,102
Re: whole house low water pressure/flow
Congrats.
Any of the houses I've owned with softeners have had them plumbed for the whole house with the exception of the outside bibs (elevated sodium [?] levels are hard on grass and plants) and, in one case, the kitchen cold. I have read this is often done because the higher sodium level may be a problem for some health conditions. The logic I suppose is that consumption and cooking is obviously most common from this tap. I have both a hard and soft bib in my garage which makes it really nice for vehicle washing - no water spots.
lenaitch is offline   Reply With Quote
Old 01-03-2017, 09:11 PM   #17
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,878
Lenaitch.... That makes a heck of alot of sense.....
But... Let me ask.... did you custom build and realize the hard water issues...
it was great preplanning.... or were you just able to redo your plumbing...
I ask... as I've just moved into a hard water area... and the plumbing is "standard". I have installed a water softner and am thinking out your points.
Best
MTN REMODEL LLC is offline   Reply With Quote
Tags
low water flow , low water pressure
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
No water in house dls6w4 Plumbing 10 02-12-2011 06:45 AM
