Whole House Humidifier Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2015, 10:19 AM   #1
Rewards Points: 64
Hello, I am currently working on installing a whole house humidifier and am having trouble figuring out how to plumb the waterline to it.
The closest existing line is in my water heater closet, and the line I need to cut a tee into is 3/4-inch PEX. The humidifier calls for 1/4-inch O.D. copper. I would also like to put a shutoff valve right after I cut into the existing PEX.
The nice lady at Home Depot put together a package of fittings totalling over $90 and it included 6 sharkbite connections (2 to tie into the existing PEX, 2 between the sharkbite tee and the valve, then two reducing it down again to 1/4"). If at all possible I would like to eliminate as many of these connections as possible, as I have heard they tend to leak over time.
I have read that some people have used a fitting like the Watts P-667, which does it all, except that it is made for existing 1/2" PEX and I have 3/4".
Can anyone help me figure out a more streamlined solution? Thanks for any help you can give me.
soonerce is offline   Reply With Quote
Old 12-07-2015, 01:38 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 904
3/4 x 3/4 x 1/2 Sharkbite tee $14
Short stub of 1/2 copper or PEX tubing (say 3") $1
1/2 Sharkbite male adapter $6
1/2 Threaded ball valve $8
1/2 x 1/4 brass bushing $4
1/4 compression male adapter $5
1/4 copper tubing to humidifier
If you have access to PEX crimp tools you can eliminate the Sharkbites (expensive) and use regular PEX crimp fittings
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
soonerce (12-07-2015)
Old 12-07-2015, 01:51 PM   #3
Rewards Points: 64
Thanks for your reply. I have access to a PEX crimping tool.
So, 3/4x3/4x1/2 regular tee
Short stub of 1/2 PEX
1/2 regular male adapter (do they make this?)
The rest the same?
Old 12-07-2015, 01:58 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 904
Rest the same. Plus a few 1/2 and 3/4 crimp rings
Old 12-07-2015, 02:05 PM   #5
Rewards Points: 64
Do you have pictures of these two items?
The other stuff I'm pretty familiar with, but these two are the elusive ones.
Old 12-07-2015, 02:13 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 292
I'd go 3/4x1/2 tee. Then 1/2x1/4 angle stop. You should be able to find both in sharkbite. From the stop valve run 1/4" to the unit
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
rjniles (12-07-2015), soonerce (12-07-2015)
Old 12-07-2015, 02:23 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 904
Eplumber has a great idea:
1/2" PEX barb to 1/4" compression stop.
Old 12-07-2015, 02:25 PM   #8
Rewards Points: 64
I had come to this conclusion as well at the store, then an assistant manager came to ask me if I needed help and talked me out of using sharkbite, saying they will leak. Then he sent me his plumbing manager that loaded me up with sharkbite.
I guess the real question is, do they leak? Is it worth spending a little extra money to eliminate them?
Old 12-07-2015, 02:27 PM   #9
Rewards Points: 64
I like it! So...
3/4x3/4x1/2 PEX Tee
Small piece of 1/2 PEX
1/2" PEX barb to 1/4" compression stop (as shown above)
1/4" Copper to Unit
Two 3/4" and 2 1/2" PEX rings
I'm guessing I won't find that 1/2" PEX barb to 1/4" compression stop at a big hardware store.
Old 12-07-2015, 02:28 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 904
I would not be afraid to use them in that application, but I am a cheap a$$. The Sharkbites are a lot more expensive than regular PEX fittings.
Old 12-07-2015, 02:30 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 904
And the orange or blue aprons are not the best place to get advise.
And be real careful about listening to any of us. LOL
Tags
copper , humidifier , pex , plumbing
House Humidifier - advice beengone HVAC 3 01-05-2015 11:44 AM
Recently installed Bypass humidifier. Should my house feel colder? speedster1 HVAC 9 01-10-2012 09:53 PM
Shoring and Video plumbing inspection. Is it worth it? Geaux4Tigers Plumbing 22 12-12-2010 02:48 PM
whole house humidifier mazzonetv HVAC 13 10-16-2009 08:50 PM
