DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Plumbing (https://www.diychatroom.com/f7/)
-   -   Whole House Humidifier Plumbing (https://www.diychatroom.com/f7/whole-house-humidifier-plumbing-342930/)
soonerce 12-07-2015 10:19 AM
Hello, I am currently working on installing a whole house humidifier and am having trouble figuring out how to plumb the waterline to it.
The closest existing line is in my water heater closet, and the line I need to cut a tee into is 3/4-inch PEX. The humidifier calls for 1/4-inch O.D. copper. I would also like to put a shutoff valve right after I cut into the existing PEX.
The nice lady at Home Depot put together a package of fittings totalling over $90 and it included 6 sharkbite connections (2 to tie into the existing PEX, 2 between the sharkbite tee and the valve, then two reducing it down again to 1/4"). If at all possible I would like to eliminate as many of these connections as possible, as I have heard they tend to leak over time.
I have read that some people have used a fitting like the Watts P-667, which does it all, except that it is made for existing 1/2" PEX and I have 3/4".
Can anyone help me figure out a more streamlined solution? Thanks for any help you can give me.
rjniles 12-07-2015 01:38 PM
3/4 x 3/4 x 1/2 Sharkbite tee $14
Short stub of 1/2 copper or PEX tubing (say 3") $1
1/2 Sharkbite male adapter $6
1/2 Threaded ball valve $8
1/2 x 1/4 brass bushing $4
1/4 compression male adapter $5
1/4 copper tubing to humidifier
If you have access to PEX crimp tools you can eliminate the Sharkbites (expensive) and use regular PEX crimp fittings
soonerce 12-07-2015 01:51 PM
Thanks for your reply. I have access to a PEX crimping tool.
So, 3/4x3/4x1/2 regular tee
Short stub of 1/2 PEX
1/2 regular male adapter (do they make this?)
The rest the same?
rjniles 12-07-2015 01:58 PM
http://www.homedepot.com/catalog/pro...f40a5d_145.jpg
http://www.homedepot.com/catalog/pro...08922c_400.jpg
Rest the same. Plus a few 1/2 and 3/4 crimp rings
soonerce 12-07-2015 02:05 PM
Do you have pictures of these two items?
The other stuff I'm pretty familiar with, but these two are the elusive ones.
TheEplumber 12-07-2015 02:13 PM
199 Attachment(s)
I'd go 3/4x1/2 tee. Then 1/2x1/4 angle stop. You should be able to find both in sharkbite. From the stop valve run 1/4" to the unit
rjniles 12-07-2015 02:23 PM
Eplumber has a great idea:
http://www.homedepot.com/catalog/pro...9f039d_400.jpg
1/2" PEX barb to 1/4" compression stop.
soonerce 12-07-2015 02:25 PM
I had come to this conclusion as well at the store, then an assistant manager came to ask me if I needed help and talked me out of using sharkbite, saying they will leak. Then he sent me his plumbing manager that loaded me up with sharkbite.
I guess the real question is, do they leak? Is it worth spending a little extra money to eliminate them?
soonerce 12-07-2015 02:27 PM
I like it! So...
3/4x3/4x1/2 PEX Tee
Small piece of 1/2 PEX
1/2" PEX barb to 1/4" compression stop (as shown above)
1/4" Copper to Unit
Two 3/4" and 2 1/2" PEX rings
I'm guessing I won't find that 1/2" PEX barb to 1/4" compression stop at a big hardware store.
rjniles 12-07-2015 02:28 PM
I would not be afraid to use them in that application, but I am a cheap a$$. The Sharkbites are a lot more expensive than regular PEX fittings.
rjniles 12-07-2015 02:30 PM
And the orange or blue aprons are not the best place to get advise.
And be real careful about listening to any of us. LOL
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
